FlySky GT3b Hack Tech Thread
#46
I borrowed my buddies hacked GT3b yesterday to try it out and ran into a problem. I ran it one time, worked great. I broke the truck I had the receiver in, so I popped it out and put it in my buggy. I needed to reverse the servo so I pushed down the selector knob to access the menus.All it di was coonstantly swap between Model and Name. No matter what I did, it wouldn't do anything else. Any ideas?
Thanks in advance!
Thanks in advance!
#47
Thanks in advance!
Thanks in advance!
#51
Ok, been trying to figure this out for hours. I have a snapped board at this point and no luck. Have tried everything I can find but I cant get past swim error when trying to flash. The radio light turns off so I know that there is some kind of communication going on but it errors no matter what I do... Any suggestions?
#54
Well found a way to get rid of using double AA battery and use a lipo for longer run time and lighter weight on the radio.
Original weight in grams
Taking out the tray
Solder job and connector
Battery
Finalized weight
Taking out the tray
Battery
Finalized weight
#58
I read mod firmware and found this source provides non divided external clock source 18.432MHz exceed device specification of 16.0MHz.
Is it correct? However, IMO, small OC such like this should have none of problem.
#60
I am also having issues with the custom firmware, I have the GT3B-0.61 firmware, I am trying to get the steering to both have the 150% end point, however I can only select the end point for steering right. It's in channel 1 and esc is in channel 2.
Can anyone help me!! Thanks!
1Likes
. 2 bad cables, who would have thought...
