FlySky GT3b Hack Tech Thread >
Like Tree1Likes
Old 04-30-2012 | 06:15 PM
  #46
Toypainter's Avatar
I borrowed my buddies hacked GT3b yesterday to try it out and ran into a problem. I ran it one time, worked great. I broke the truck I had the receiver in, so I popped it out and put it in my buggy. I needed to reverse the servo so I pushed down the selector knob to access the menus.All it di was coonstantly swap between Model and Name. No matter what I did, it wouldn't do anything else. Any ideas?
Thanks in advance!
Toypainter is offline
Old 05-01-2012 | 05:25 AM
  #47
psx
Thanks in advance!
You pressed selector for long time probably and it entered global setting menu (it is indicated by alternating blinking NAME and MODEL).
psx is offline
Old 05-01-2012 | 01:36 PM
  #48
Toypainter's Avatar
Psx, thanks for the reply. How do I fix it?
Old 05-01-2012 | 01:43 PM
  #49
psx
What do You wan to fix ? If You press selector shortly, it will enter usual menu. If You press it for long (about 1s), it will enter global setup.
psx is offline
Old 05-01-2012 | 05:06 PM
  #50
Toypainter's Avatar
Oh! I see what I'm doing wrong. Thanks!
Old 05-03-2012 | 02:59 PM
  #51
SCStephens's Avatar
Ok, been trying to figure this out for hours. I have a snapped board at this point and no luck. Have tried everything I can find but I cant get past swim error when trying to flash. The radio light turns off so I know that there is some kind of communication going on but it errors no matter what I do... Any suggestions?
SCStephens is offline
Old 05-03-2012 | 07:40 PM
  #52
SCStephens's Avatar
Got it, sometimes you just have to walk away for a couple of hours . 2 bad cables, who would have thought...
Old 05-04-2012 | 01:29 PM
  #53
Any programers going to be at Trackside for the Showdown this weekend?? I would like to get reprogramed if possible.
Mark
mark in wi is offline
Old 05-04-2012 | 09:33 PM
  #54
outoforder's Avatar
Well found a way to get rid of using double AA battery and use a lipo for longer run time and lighter weight on the radio.
Original weight in grams
Taking out the tray
Solder job and connector
Battery
Finalized weight
Spharticus likes this.
outoforder is offline
Old 06-05-2012 | 09:15 PM
  #55
Who does the reprogramming now in CA? Mattyhawk link is dead. Anyone use the service before?
sffan15 is offline
Old 11-18-2012 | 09:22 PM
  #56
is the turnigy gtx3 exactly the same internally as the gt3b ?
wantboost is offline
Old 11-18-2012 | 09:41 PM
  #57
losikid67's Avatar
some people have complained that it won't take the new firmware
losikid67 is offline
Old 01-01-2013 | 10:38 PM
  #58
Default Clock frequency of mod firm.
I read mod firmware and found this source provides non divided external clock source 18.432MHz exceed device specification of 16.0MHz.
Is it correct? However, IMO, small OC such like this should have none of problem.
hayataro is offline
Old 01-19-2013 | 02:25 AM
  #59
Anyone have the original firmware for the radio? or how do i download it out of the radio?
bhilly82 is offline
Old 01-19-2013 | 06:27 AM
  #60
I believe you can download it from the Radio by going to Read, Current Tab, and then saving the file, however this didn't work for me, I have someone elses original firmware though, here you go.\
I am also having issues with the custom firmware, I have the GT3B-0.61 firmware, I am trying to get the steering to both have the 150% end point, however I can only select the end point for steering right. It's in channel 1 and esc is in channel 2.
Can anyone help me!! Thanks!
File Type: zip
Spooke is offline
