RC10B4.1 FT/WC
Old 05-03-2012 | 08:32 AM
  #14266
Originally Posted by Autocratic
Anyone? I've posted about three times now...
Can you fit velvet BB on the B4? Most are just doing the bb spring upgrade at our track.
goin2drt is offline
Old 05-03-2012 | 08:35 AM
  #14267
I tried the Avid springs this past weekend and found that my buggy jumped way better but it did feel bouncier.
Overall I feel that the springs were a good investment.
I was using the orange/yellow Losi springs prior to switching.
I used Yellow rear, red front Avids.
Rears - ■Yellow: Rate: 1.99lb | Wire: 1.17mm | Coil: 12.50 | Length: 63mm | ID: 16.25mm
Fronts - ■Red: Rate: 3.28lb | Wire: 1.17mm | Coil: 7.75 | Length: 44mm | ID: 16.25mm
Front Oil - 35
Rear Oil - 30
This setup was for Norcal Hobbies - indoor.
riggidy is offline
Old 05-03-2012 | 09:12 AM
  #14268
Originally Posted by Kuya_Kimo
I believe it's orange front and yellow rear. The red/yellow were the first wave of springs since it's matched the losi 22 but since it's progressed.
If you look compare spring rates, the orange/yellow are considered 0.1 tighter and identify with the green/brown AE ones (although big bore springs do feel softer).
Thanks for your input!
danielXIII is offline
Old 05-03-2012 | 02:29 PM
  #14269
Are Velvet BB shocks still a good investment or would it be better to wait for AE to release their BB?
It's a subjective question, my quick answer: NO.
How much money do you have? Do you have $180 to burn (with correct springs)? Will it feel smoother, probably yes. Will it make you a better driver, probably not.
I know a guy who has it on his buggy and it doesn't make him a better driver.
Kuya_Kimo is offline
Old 05-03-2012 | 05:21 PM
  #14270
Andrew Selvaggi's Avatar
Rookie question. New JC inverse rims, what are people doing for air holes? Drilling Rim? hole in tyre?
Andrew Selvaggi is offline
Old 05-03-2012 | 05:26 PM
  #14271
SoccerSting's Avatar
I don't have an answer but what is the point of those rims?
SoccerSting is offline
  #14272
rcduder's Avatar
most likely hole in the tire as most people run closed cell foam and cover up the wholes on the wheels and run a hole in the tire anyways
rcduder is offline
Old 05-03-2012 | 05:38 PM
  #14273
SAMCRO's Avatar
Originally Posted by t0p_sh0tta
Finally tried a set of Losi springs last night, with the shorty pack and it was awesome. Fastest I've ever run. Felt much smoother than the Brown/Green AE combo.
That is awesome. Which ones did you run?
SAMCRO is offline
Old 05-03-2012 | 10:44 PM
  #14274
pink_sleeve's Avatar
The back side is dished so dirt and mud can't pack in the wheel.
pink_sleeve is offline
  #14275
Both
Old 05-04-2012 | 04:47 AM
  #14276
t0p_sh0tta's Avatar
I ran the softer Red/White combo, as I was also running a Promatch shorty all the way forward.
I'm running a modified Worlds setup with #2 pistons all the way around, Losi 32.5F/27.5R, and it feels pretty good, but a bit high. I'll play with the ride heights this weekend.
For weight, I'm just running the AE ballast, and 14g under the front bulkhead.
t0p_sh0tta is offline
Old 05-04-2012 | 10:01 AM
  #14277
onefast8's Avatar
To get you to spend your money to keep up with the Joneses.
onefast8 is offline
Old 05-04-2012 | 10:37 AM
  #14278
elex300's Avatar
So if I run a full stick pack I should go with the stiffer set up of Losi BB Yellow rears and orange fronts?
elex300 is offline
Old 05-04-2012 | 10:39 AM
  #14279
Originally Posted by danielXIII
What's the favorite losi spring combo for wcrc?
Running orange front/yellow rears have been good for me as well. Seems to be the popular combo at WCRC
Are Velvet big bore shocks still a good upgrade investment, or would it be better to use the kit small bores and wait for AE to release their own?
+1. Kyosho big bores are a smoother set up but at what price? Set of shocks for the price of a buggy roller? But Kyosho BB are so last month. The new flavor of the day is Avid springs. It seems that everyone likes to jump on every new fandangled gizmo that comes out. Did you see the pic of (insert pro driver's name here) prototype (insert part name here). I gotta get it! No you don't! You wont drive like said pro. Check your lap times. How much faster did you get swapping let say springs? Mid pack times to now TQ? I guess it's like women and Victoria Secrets. They could just as well wear cheaper Hanes No one sees their underwear but it makes them feel better knowing that they're wearing Vicky's secret.
It's the indian not the arrow!
jamr1130 is offline
Old 05-04-2012 | 10:47 AM
  #14280
+1 what he said
timee80 is offline
