Lipo taking a looooong time to charge / balance
#16
During the charging process weaker cells will hit 4.2v first
The balancing process uses bleed current to stop them from over-charging while the other cells catch up
Better chargers have a higher bleed current so are able balance more effectively
Crappy charger may have a 50 mah bleed current
Most decent chargers will have around 300 mah
Revo Powerlabs have a 1 amp bleed current
Higher the bleed current quicker the charger is able to balance mismatched cells
Faster the cells are balanced, quicker the charge cycle takes to finish
Badly mismatched cells are sometimes not able to be balanced using lower bleed currents, hence the reason why balance charging takes forever on cheap chargers
Cheers
Cheers
#17
One of my best friends was religious about balancing and was constantly having packs go bad from all different brands. I told him how I don't balance at all. He stopped balancing for the most part, just every once in a while. He hasn't lost a single pack since.
I personally don't balance any packs.
1) I'm lazy
2) I like to see worst case scenarios. I run packs hard, don't properly put them in storage mode, leave them fully charged, leave them discharged, etc. Out of 100 or so packs routinely in use, I very rarely have any go bad.
Is it a good idea to maintain them from time to time. Yes.
And as always, your mileage may vary. This is my experience.
Paul Susbauer
Venom Group Int.
BTW... I'll be away from internet contact for the next week or so, so you probably wont see any responses for a bit. Not hiding, I'll be back.
#18
INTERESTING THREAD, THE UNKNOWN OF BALANCING ALL THE TIME VS NOT BALANCING, WHO REALLY KNOWS? I JUST RECENTLY SWITCHED TO A CHECKPOINT WITH PRO BALANCER FROM A ICE WITH BLINKY BALANCER AND NOTICED MY CHARGE TIME HAS ALMOST DOUBLED DONT KNOW WHY.
#20
Cheers
Cheers
Where did you find the value for the bleed current?
#21
Bleed / balancing current is usually listed in the manufacturers specs if you dig hard enough
Only reason to not balance is if you are in a hurry (at the racetrack between races)
Think people misunderstand why we do balancing at all
The only reason is to stop weak cells being overcharged during the charge process
If you are using decent packs on a decent charger it only adds a few minutes
Charging at 2c from storage voltage should only take 20 minutes or so
Cheers
Cheers
