Like Tree1Likes
B44.1 Thread
Old 04-29-2012 | 10:03 PM
  #2011
smittyusmc's Avatar
Originally Posted by TJMac
I'd run the Race on the B4 and the Pro in the B44. 6.5 + 4wd is going to put more stress on the ESC than an 8.5 in a 2wd.
Biggest difference is amps. Race is 90amps and the Pro is 160 (2-3s version).
Thank u for your help will I have any problems with the race being in the 2wd. I really dont understand what the 90amps means over the 160amps.
smittyusmc is offline
Old 04-29-2012 | 10:29 PM
  #2012
Originally Posted by 20 SMOKE
POSITION
CHARACTERISTICS
Forward holes (sharper angle)
• Smoothens out steering response
• Car reacts smoothly
• Better suited to smooth fl owing tracks with
high speed corners
Rearward holes (shallower angle)
• Quickens initial steering response
• Car reacts faster to steering input
• Better suited to small, tight tracks
Thank you Jamie for your fast reponce. I will definately try the forward hole setting.
Larren is offline
Old 04-30-2012 | 02:57 PM
  #2013
fastchvy's Avatar
Im running avid springs and wow!
fastchvy is offline
Old 04-30-2012 | 03:11 PM
  #2014
Has anybody had a problem with front slipper drive cup, the pin that is in it keeps sliding out from the o-ring??
TheHillsPancake is offline
Old 04-30-2012 | 03:13 PM
  #2015
fastchvy's Avatar
Does the o ring come off?
fastchvy is offline
Old 04-30-2012 | 03:21 PM
  #2016
No it doesn't it just gets pushed out of the way by the pin
Old 04-30-2012 | 03:25 PM
  #2017
fastchvy's Avatar
Replace the few peices and see if it does it again
fastchvy is offline
Old 04-30-2012 | 03:27 PM
  #2018
Replace the slipper out drive cup?
Old 04-30-2012 | 03:28 PM
  #2019
fastchvy's Avatar
The pin, the plastic cup and o ring
fastchvy is offline
Old 04-30-2012 | 03:58 PM
  #2020
Why the wow? Are you impressed. Please explain and desribe your set up
zipperfoot is offline
Old 04-30-2012 | 04:02 PM
  #2021
I replaced the pin but I couldn't replace the plastic out drive cause west coast doesn't have one in stock... Any other suggestions?
Old 04-30-2012 | 04:04 PM
  #2022
fastchvy's Avatar
I have been running kyosho big bore springs for awhile now and ran the new avids over the weekend and was way better. Car had a ton more grip, on power, off power, and even on a high speed sweeper...i wish i can fill out a set up sheet and then post a link, i would like some people to try my set up to see what they think
fastchvy is offline
Old 04-30-2012 | 04:08 PM
  #2023
fastchvy's Avatar
If your just trying to run till you get parts then maybe put a little ca glue on the end of the pin and some on the bring so it can't push away, i just took mine apart last week and had a hard time getting the pin out so i think you might have a worn out plastic cup and maybe a stretched o ring
fastchvy is offline
Old 04-30-2012 | 08:58 PM
  #2024
TJMac's Avatar
You shouldn't have any problems.
They rate them according to how much juice they can handle. A 160amp ESC can handle more power than a 90amp ESC. That doesn't mean the 90amp ESC isn't any good, it just means you can't run crazy low turn motors. I run a Race in my daughters SC10 in 17.5 blinky and the ESC is so under stressed its ridiculous. She's run 15-20 minutes at a time practicing and the Race comes off the track @ 110-115F without a fan. You should have no issues running an 8.5. My only concern would be to check temps after 6-7 minutes if you decide not to run the fan (or can't .... B4 is a little tight).
TJMac is offline
Old 04-30-2012 | 09:10 PM
  #2025
TJMac's Avatar
Originally Posted by zipperfoot
I have never seen anyone else with this problem, and have never had this problem occur with the two B44's and two B44.1's i have owned. Is this happening to the same shocks over and over? It must be the clips or shafts. Front or rear? Are you using stock pistons? The c clips are seated properly and click when you install them into the grove? If all these requirements are met then i have no idea. When you figure this out please share the results.
I was about to post the same thing. I've been around the hobby for 25+ years and I've never seen that happen, not once. Very strange. I'd replace the shaft and clips and make sure they're clicking into place (like you said).
TJMac is offline
