Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 04-20-2012 | 04:52 PM
  #16966
durtbag's Avatar
Originally Posted by caltek1
My current MO5L.
Nice Ride! My current M05S 17.5, 3Racing gear diff, Super Slicks. thing is on rails.
durtbag is offline
Old 04-20-2012 | 05:06 PM
  #16967
durtbag's Avatar
and my other toy.
durtbag is offline
Old 04-20-2012 | 05:24 PM
  #16968
caltek1's Avatar
Thumbs up
Looking good. I can't say I have tried the super slicks. Here we would get left behind with the little tyres.
Your big toy looks great.
Later,
Calvin
caltek1 is offline
Old 04-20-2012 | 06:17 PM
  #16969
durtbag's Avatar
Later,
Calvin
Can you give me the part#'s for the tires you guys are using? Are they Sweep pre-mounts? Going to need a harder coumpound for ashpalt.
Thanks, Terry
durtbag is offline
Old 04-20-2012 | 08:47 PM
  #16970
Originally Posted by Granpa
I have several sets of the Mini shocks, but do not like them. Because of the small oil volume, the shock action can be erratic. They are okay on the higher grip tracks, but do not work as well on parking lot or outdoor asphalt tracks which are usual lower grip. These surfaces usually require softer springs and more suspension travel. A situation that does not favor the small Mini shocks.
What would you recommend then? I run on those surfaces on the CVA mini, and I do sometimes feel there's not enough travel. Perhaps take out the internal spacer?
stocker is offline
Old 04-21-2012 | 04:49 AM
  #16971
Is Kimbourgh servo saver better than Tamiya Hi-torque one ?
Vrooom is offline
Old 04-21-2012 | 05:06 AM
  #16972
Kimbrough is 100 times better. Tamiya Hi-torque has lots of slop. Superglue and some small plastic can help take out the slop.
rccartips is offline
Old 04-21-2012 | 12:36 PM
  #16973
TAMAK's Avatar
Hey guys selling my X-evo and enough parts to build a M03M. http://www.rctech.net/forum/r-c-item...ini-bling.html
TAMAK is offline
Old 04-21-2012 | 01:34 PM
  #16974
Anyone run and fit Traxxas XL-5 ESC on M05? they are bit too big but can anyone fit those? how are they?
I need new esc that can run brushed 20T motor and run lipo batteries with low voltage cut off.
Vrooom is offline
Old 04-21-2012 | 08:31 PM
  #16975
The TC TRF shocks. By using different piston rod lengths and internal spacers, you can get the type of shock action you want. There is a lot of flexibility here. It has nothing to do with the amount of travel, but has more to do with how much roll you want or side to side weight transfer. Or stated another way, how smoothly the shock works throughout especially on the compression side.
In the Mini shock, your choices are very limited and you can't get around the smaller oil volume. If you analyze it, you'll be able to figure out why the smaller oil volume can work against you in some cases and for you in others.
Granpa is offline
Old 04-22-2012 | 04:09 PM
  #16976
marcos graveyar's Avatar
Originally Posted by wollow86
Anybody know where I can get the Ride Body Post Brace ? I can't seem to source it anywhere
marcos graveyar is offline
Old 04-23-2012 | 08:48 PM
  #16977
Check with Sean at TQ, I believe he ships internationally. He usually has this in stock.
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
back9monsta is offline
Old 04-24-2012 | 04:16 PM
  #16978
jsr555's Avatar
Default Tamiya Springs
Are the M0-5 kit springs, the 3 white sets with a blue, red and yellow dot on them, the same size and weight as the Tamiya TRF Springs, ie the red (53630), Yellow and Blue (53632) srings etc.
Thanks.
jsr555 is offline
Old 04-25-2012 | 05:20 AM
  #16979
Hi Guys
Bit new to this forum. Been racing my m05 here in the uk for 5 years now. I'm running a blinged s spec. My club has just changed to brush less to m chassis class.
Took my m05 apart last night to fit new 3 racing gear diff.... then realised i was missing 2 rather large bearings needed??? either side of the out drives! why 3 racing don't include this in the kit is beyond me?? anyhow had to build her back up with the original kit diff, re lubed.
I just hope the kit diff holds up with the new torque from the hobbywing 13t brushless combo.
Any tips on running kit diff with brush less system for longevity?
Cheers
Damien.
DameTRF416 is offline
Old 04-25-2012 | 06:15 AM
  #16980
Thanks.
Yes.
mariob62 is offline
