SC10 4x4 Thread
Pretty much everyone locks the clicker down and does not use over/underdrive. Stock settings will get it rolling but your best bet is to find a set up sheet that resembles your track and start there. AE's site has some listed.
Interesting picture, not one time during the event would those tires work , maybe that pic was from friday practice because from what i saw Jconcepts 3d's were the tire of choice on sunday.(which sucked azz for me!!)
pretty much running the same set up with the pro4 4600, 14 on the pinion and stock spur, medium size track with loose dirt. I only ran two packs through the truck on its shake down run and came off at 145 with a reedy 60c 5500 lipo stick pack. So far so good, this weekend will tell the trueth at the Michigan State points race.
http://www.myrcbox.com/news/team-dom...MyRCBox.com%29
You already know I'm always a little skeptical when it comes to setup sheets, but I'm glad to see I'm not the only one who's running Kyosho springs in my 2w SC.
You need to Just Calm Down
I love you Craig
Do me a favor sense you have the parts ...
Please weight the metal basket part & the Ae plastic basket and give me the weight ....
I'm glad to see that even me being gone, WC hasn't changed his spewing of misinformation.
Hey buddy.
I have the new FT VTS slipper clutch and the center diff. I prefer the center diff. Not only does it hook up better, it handles better too. I am able to run lower weight front diff fluid which gives me better handling in the turns. For the money, it is the best mod you can buy for the truck after the sway bars.
Even now with the added weight of the Exotek chassis on 15/60(center diff) the 4000 is still more than enough motor the keep pace with other 4x4. Your 4600 will be a beast!
Edit: CraigMBA already weighed the two.
Robinson will be fine but if they don't have a 32p get the mod .08. It is the same pitch.
The pissing contest really draggs the thread down.
What's the consensus on the FT team kit? Does it fix all of the shortcomings of the regular kit? Anything to look out for besides the sagging arms?
5Likes
AE says we FAIL, stick pack is fast too if the driver is.
