RC10B4.1 FT/WC
The advice I will give is try to figure where you will eventually be. If you think you want to go mod buy an 8.5 or something around that range and dial the motor back, there are a few different ways to do that. If you think you want to run stock get a 17.5 or 13.5 and have a blast. I work on a sprint car and the only similarity I have found is that I simply have a better idea, and ability, to fix it when I break it.
New guy here. Great thread. I am up to page 627.
I am about to buy a 4.1 WC and have a question about motors. Most of the tracks around here (Wash DC) run mod 2wd buggy. Since I assume that means any motor, what is the advantage to running an 8.5 vs 10.5 vs 13.5 etc? I race sports cars (real ones) where the stronger the motor, the better. It seems in r/c, that is not necessarily true.
Thanks for any help in advance.
Have you run RC before? I only ask as 2WD mod buggy is an optimistic entry point but hell, go for it!!!!
for a new driver, here's the best way to explain WHY you want one over the other.
17.5 - easiest to drive because you use full range of motion with trigger.
13.5 - next easiest to drive because you use full range of motion with trigger, just go a bit faster
8.5 - uses less trigger range of motion because of the amount of power. If setup right, you will usually use about half of your trigger. Fast guys will be able to work in more than slower guys. Harder to drive when you have half the throttle range as the 17.5 and twice the power.
All in all, if you were only getting 1 motor, I would say get a 13.5 and add boost until you can make it around the track and be less than 1 second off the fast guys per lap. After that, move up to a 9.5. You will have more power than you know what to do with. I ran an 8.5 and wished I had bought the 9.5 instead because I would have been able to control it better.
Yeah, nothing lasts forever
I wanna see both sides of the coin. I ran two times a week with the 4.1 for a solid 6 months. Gonna give the 22 a shot for a while, learn it a bit, and hopefully be better off because I will know how to help guys with questions like I can with the 4.1
Not to mention I was planning on getting a new kit either way this winter
Thanks everyone for the quick and thorough replies. Yes, this will be my first time racing an r/c car, although my son has a t4.1 that I play with in the street. I know it is an aggressive move to jump right into mod 2wd buggy but 1) that is the primary class around here, and 2) my real race car sucks up all my $$$, so I only have one shot to get into this.
Zeakemedia, do you find that your car setup skills xfer to the r/c world? I am really good at car setup.
I don't think I'm gonna get to p800 let alone 600 odd; how are the V2 shocks holding up in terms of leakage? Does one need to file/sand/replace the bushings to get a perfect fit? Do the O-rings rip as easy as it used to?
How do they compare to Kyosho's? Are the Prolines better than the V2s?
Thanks,
Thanks,
Thanks,
Thanks,
Thanks,
Thanks,
The only difficulty I had was getting the bleeder screw going in the cap. I discovered that if you use your 1/16 allen wrench and jam/tap it through the hole, it creates a much better pilot hole for the bleeder screw, while still being small enough to not allow any leaking.
