Like Tree5Likes
SC10 4x4 Thread
Old 03-28-2012 | 06:43 AM
  #20206
Evil Genius jr.'s Avatar
Originally Posted by JEFFs SC10
I'm probably going to swap out my savox, I like it but it is too power hungry and causing me brownouts.
For anyone who thinks Savox servos are not very power hungry.
http://www.ultimaterc.com/forums/sho...d.php?t=146355
Evil Genius jr. is offline
Old 03-28-2012 | 07:19 AM
  #20207
JEFFs SC10's Avatar
JEFFs SC10 is offline
Old 03-28-2012 | 07:20 AM
  #20208
Agreed. They draw some insane power causing voltage fluctuations.
  #20209
While the sc104x4 thread is not the best place to discuss.....
Does your lab scope/probe have the ability to measue current draw? By your scaling on the lab scope it looks like your running 5v BEC voltage. What does it look like at 6v?
Really that graph doesn't prove that the Savox is power hungry. It proves that the MMP can't handle the current requested by the Savox and the Spektrum RX has a minimum voltage around 3 volts.
I'm curious about how my Viper ESC would handle that same test, would it drop voltage. It could be that the MMP really only outputs less then 3 amps.
thefatkid is offline
Old 03-28-2012 | 07:22 AM
  #20210
No it doesn't my Dmm does though..... That scope can only use 5V, its a cheap USB one.
I'm going to try another servo to see the results.
Old 03-28-2012 | 09:07 AM
  #20211
Wild Cherry's Avatar
Originally Posted by jamr1130
You got something going on with the CF B4.1 C-towers and raised camber link. Hmmm.
TY
Another little improvement that actually works ......
Wild Cherry is offline
Old 03-28-2012 | 09:13 AM
  #20212
So it raises the outer link higher which raises the roll center, right?
And that does......?
Old 03-28-2012 | 09:17 AM
  #20213
controls the roll better , brings fewer traction roll overs ....
Old 03-28-2012 | 09:22 AM
  #20214
Cain's Avatar
+1
on the inner stud going to 7mm shims eliminated the traction rolling I had. I think about 5mm is a good position too, especially in the front for the conditions I ran on. (carpet over jumps)
Cain is offline
Old 03-28-2012 | 09:34 AM
  #20215
So how does both raising the inner one or raising the outer one reduce roll over? Aren't they exact opposites? Also has anyone put shims under the outer front camber link?
Old 03-28-2012 | 09:38 AM
  #20216
ilanstylz's Avatar
I just remembered that one other thing different about the FT kit is that it came with shims to install on both front/rear inner studs.......
ilanstylz is offline
Old 03-28-2012 | 10:04 AM
  #20217
Sludge-T's Avatar
I have the Gens Ace 6000 saddles and in order to use the b44 mounts you need to add a spacer under the post or a longer screw on top. I will post some pics tonight on what I did to get my 6000's installed.
Will the B44.1 setup work with the tall Gens Ace saddles and the exotek chassis?
Sludge-T is offline
Old 03-28-2012 | 10:09 AM
  #20218
The MMP only has a 1.5A BEC, which is quite low.. even less power hungry servos draw more than that. Safest way is still using an external BEC, I use the 4$ Hobbyking one without any issues.
Arakon is offline
Old 03-28-2012 | 10:11 AM
  #20219
Thanks!
Old 03-28-2012 | 10:20 AM
  #20220
JEFFs SC10's Avatar
The rx8 has a 5 v bec and it can't keep up running with a pro 4.
I'm probly going with the hitec servo now.
