FlySky GT3b Hack Tech Thread
#33
#36
ok i hope you guys can help me out i will buying this radio real soon and will be doing the 8ch mod to this radio for a rc truck build im doing
when the 8ch mod is done to this radio can i put a potentiometer on each of the other ch so they work just like channel 1 and 2
i will be taking this radio apart and building a custom stick radio out of it
any info will help
any info will help
#38
Maybe I can try to temporarily connect potentiometer to CH3 button and test the same things You did.
And do You see changing values at calibrate screen for channel 3, when You have potentiometer connected ?
#40
any info will help
any info will help
1) The additional channels are controlled by the stock buttons?( trim buttons etc) or are more buttons physically added to the radio??
2)Are the additional channels 2 or 3 position?
3) can a pontentiometer be added to any of the channels?
4) how many models can be controlled? I have seen 14 and 40 mentioned?
5) the website mention a trade off of channels vs number of models- so what are the trade off specs?ie 8 channels have 10 model memory? 6 channels has 14 model memory?
6) will the radio come with additional programming instructions or is there a PDF link for instructions on the website?
Thanks I am a technical nut and want to get as much info as possible before ordering
#41
When You assign one button to control it, it will change between -100 and 100. If You use digital trim to control it, arbitrary value between -100 and 100 can be set by clicking those buttons. And there are much more settable possibilities.
http://www.rctech.net/forum/9935672-post2986.html
#42
any one having issues with the GT3B not working properly with VRC? i went into setting and set everything up for it just its not working,,the trim seems to be off,, i calibrated it and same issue,,,btw the trim setting on the controller dont do anything in game.
#44
1Likes
