FlySky GT3b Hack Tech Thread >
Like Tree1Likes
Old 03-27-2012 | 10:06 AM
  #31
dtr's Avatar
dtr
Is it possible to mod a potmeter instead of the switch to channel 3? Will the PSX fw cope with it?
dtr is offline
Old 03-27-2012 | 10:37 AM
  #32
yes, and I believe the alternate firmware can use it.
derelicte is offline
Old 03-27-2012 | 10:57 AM
  #33
losikid67's Avatar
No, its supposed to work, but it don't. I've been looking through the code to try and figure out why, but i haven't seen nothing yet...
losikid67 is offline
Old 03-27-2012 | 01:59 PM
  #34
dtr's Avatar
dtr
Thanks Losikid, some crawler guys around here want this feature to have smooth control over an added braking servo.
dtr is offline
Old 03-27-2012 | 02:02 PM
  #35
losikid67's Avatar
Interesting, mechanical brakes on a crawler...got a picture?
Old 03-27-2012 | 10:58 PM
  #36
td-civ's Avatar
ok i hope you guys can help me out i will buying this radio real soon and will be doing the 8ch mod to this radio for a rc truck build im doing
when the 8ch mod is done to this radio can i put a potentiometer on each of the other ch so they work just like channel 1 and 2
i will be taking this radio apart and building a custom stick radio out of it
any info will help
td-civ is offline
Old 03-28-2012 | 12:36 AM
  #37
dtr's Avatar
dtr
Not yet, they're in the planning stage.
dtr is offline
Old 04-12-2012 | 10:42 AM
  #38
psx
If it don't work, just write me what exactly You did, how You setup model in radio config and what it was doing then. I will try to look at it at the code.
Maybe I can try to temporarily connect potentiometer to CH3 button and test the same things You did.
And do You see changing values at calibrate screen for channel 3, when You have potentiometer connected ?
psx is offline
Old 04-14-2012 | 06:00 AM
  #39
sapperguy2000's Avatar
so much info thank you very much losikid
sapperguy2000 is offline
Old 04-15-2012 | 02:04 AM
  #40
any info will help
I am curious for this answer also
1) The additional channels are controlled by the stock buttons?( trim buttons etc) or are more buttons physically added to the radio??
2)Are the additional channels 2 or 3 position?
3) can a pontentiometer be added to any of the channels?
4) how many models can be controlled? I have seen 14 and 40 mentioned?
5) the website mention a trade off of channels vs number of models- so what are the trade off specs?ie 8 channels have 10 model memory? 6 channels has 14 model memory?
6) will the radio come with additional programming instructions or is there a PDF link for instructions on the website?
Thanks I am a technical nut and want to get as much info as possible before ordering
noir522 is offline
Old 04-15-2012 | 06:52 AM
  #41
psx
Yes, by the stock buttons.
There are values between -100 to 100 (1ms-2ms servo signal length).
When You assign one button to control it, it will change between -100 and 100. If You use digital trim to control it, arbitrary value between -100 and 100 can be set by clicking those buttons. And there are much more settable possibilities.
One additional potentiometer can be connected instead of CH3 button, but there is no code in sources to handle this yet (but it is possible to do it).
Some early versions have 40 model memories. Then I added more functions and now there are 17/14/12 model memories for 3/6/8 channel firmware.
Look at this post:
http://www.rctech.net/forum/9935672-post2986.html
psx is offline
Old 04-15-2012 | 07:04 AM
  #42
any one having issues with the GT3B not working properly with VRC? i went into setting and set everything up for it just its not working,,the trim seems to be off,, i calibrated it and same issue,,,btw the trim setting on the controller dont do anything in game.
Old 04-23-2012 | 04:29 PM
  #43
Is the ch3 button a toggle button or a pushbutton?
Sokonomi is offline
Old 04-25-2012 | 02:01 AM
  #44
psx
It is hardware push button. But usage depends on firmware. Original firmware uses it as toggle button. In my firmware You can choose between toggle and push.
psx is offline
Old 04-25-2012 | 02:08 AM
  #45
Heh ok, looks like ill be flashing this puppy then.
I need a momentary switch for my FPV trucks claxon.
Thanks!
Sokonomi is offline
