1/12 forum
Easiest way to measure it is droop over ride height. Basically just measure the ride height at the front of the pod and then lift up on the upper shock pivot until you have maxed out the shock's extension, and then measure ride height again. The difference in measurements is your pod droop.
- Speed Merchant Rev6 - Bruce Carbone - Pod Droop vs Chassis Sag -
http://www.petitrc.com/reglages/spee...hassisSag.html
Bruce is actually who taught me all of that stuff.....
So. Thought posting this idea/link in here might help it not get buried as it is something we all want at some point or another with foams/traction compound.
http://www.rctech.net/forum/radio-el...able-expo.html
But I also would like a cheap portable AMB timing set up so I can use it at home with friends.
I personally Run the Futaba 3pm and the Dual rate switch is located just on my thumb of my trigger hand and I find I can only adjust it down the straight and even then my attention diverts and I stop steering properly and can never get a fast lap while changing settings
But I can change them so that's ok too.
I would like to see something easier to switch or automatic as no matter what you do on low traction surfaces you will need more steering over the course of a race.
Cheers
Cheers
I use expo to set the end points so I don't over stress the servo or have it stress the suspension trying by trying to steer past the physical limits of the suspension. After that I use just dual rate for tuning.
2991Likes
