Like Tree2991Likes
1/12 forum
Old 02-27-2012 | 07:49 AM
  #37771
DesertRat's Avatar
Castor: Angle of the kingpin in relation to a vertical plane as viewed from the side of the car.
Increase the angle - Make the car more stable out of the turn as well as down the straights and increase steering entering a turn.
Decreasing the angle - Make the car feel more “touchy” at high speeds and help steering while exiting the turn. Less Castor – More front grip, more steering.
Lower Castor Angle – Better on slippery, inconsistent & rough surface.
Higher Castor Angle – Better on smooth, high traction track.
Reactive Castor – Amount of castor change when the front end of the car is compressing (diving) or decompressing (rising).
Increase the angle – Make the car react quicker & offer more steering.
Decrease the angle – make the car easier to drive smoothly into corners.
My experience is that with less static and reactive caster, the car tends to corner in an almost linear manner, holding a certain grip through the corner without a heavy turn-in or push on exit. More static and reactive caster tends to make the car "twitch" into the corner as you go off power, and then push a bit on exit. I would suggest less static and reactive caster for a flowing track, and more for a track (such as mine) that has lots of tight hairpins.
Just remember, what works for one car and driver might not work for another.
DesertRat is offline
Old 02-27-2012 | 07:54 AM
  #37772
CarbonJoe's Avatar
Regional Moderator
Originally Posted by FST4RD
Been offered a Serpent S120 t-bar for real cheap. Only thing is that the metal rear end is slightly bent and needs replacing.
Been looking online and not able to find new rear ends for them.
Am I better off just splashing out and getting a S120L?
That was a solid car, but the rear pod is about $80 USD to replace. You can get one here:
http://www.serpentamerica.com/shop/p...&cat=29&page=1
CarbonJoe is offline
Old 02-27-2012 | 11:33 AM
  #37773
Thanks for all the replies guys!
So what's the difference between the Associated RC12R5 and the 12R5.1 apart from the $60usd odd price tag?
Is it worth spending the extra money?
FST4RD is offline
Old 02-27-2012 | 12:54 PM
  #37774
Infinite 12th's Avatar
This is your money best spent
Associated 1/12 12R5.1 Kit w/LiPo Conversion Kit
Infinite 12th is offline
Old 02-27-2012 | 01:58 PM
  #37775
chris moore's Avatar
Hi all, with WGT dying at our club and 12th getting bigger and bigger I thought about getting into 12th scale.
I really just wanted a cheapish car to get into it and see if I like it. Are there any other good cars that are bang for buck?
If you decide that you want to go this route lmk, I have a brand new rear pod I'd sell for $30. I also have a 1s saddle pack for this car if your interested in that also.
Chris
chris moore is offline
Old 02-27-2012 | 02:33 PM
  #37776
superspeed's Avatar
+ YouTube Video
superspeed is offline
Old 02-27-2012 | 05:11 PM
  #37777
RedBullFiXX's Avatar
Originally Posted by chicky03
My own personal opinion and experience.
When the car dives into the turn the king pins stand up giving less castor. Less castor is less steering mainly in the middle of the turn. So basically more reactive has less steering. If you want the car to diff out less more reactive will help. I dont think the initial steering feel changes with more or less reactive as long as you are starting out with the same degree of castor. If you change from 5-10 and dont readjust the castor it will not be the same as before. Also don't assume just because the clips or spacers are the same side to side your castor angle is the same. Its best you use a camber gauge against the front of the arm/steering block/upper eyelet to tell you if they are the same. I personally like 4-5 deg castor measuring it this way.
Nice in depth analysis there chicky.
Thanks.
RedBullFiXX is offline
Old 03-04-2012 | 03:53 PM
  #37778
Anyone tried these
Old 03-04-2012 | 09:33 PM
  #37779
DesertRat's Avatar
I was thinking about getting one or two.
Old 03-04-2012 | 09:42 PM
  #37780
Grenade10's Avatar
Default Xray 1/12 Scale
I was wondering what parts would be needed to convert the X11 link car to the X12.
Grenade10 is offline
Old 03-04-2012 | 09:53 PM
  #37781
Default hello
Originally Posted by JeffC
TCHR in Minnesota. www.twincityhobby.com
thanks for the link.hope it will make sense.
horseracingtips is offline
Old 03-04-2012 | 11:52 PM
  #37782
el salvador's Avatar
Originally Posted by Infinite 12th
Anyone tried these
I have 5 of the Orion "Evil Twin Brothers", and they are excellent !
el salvador is offline
Old 03-05-2012 | 11:02 AM
  #37783
I take it the orion are the same
Old 03-05-2012 | 11:47 AM
  #37784
axle182's Avatar
Guys wondering what your suggestion would be for the best performer 17.5 motor for my 12th. We run open boost 1s. My old Orca just isnt cutting it anymore and need a new powerplant. Is there anywhere i can find the results from some of the big races along with a list of motors used? Cheers
axle182 is offline
Old 03-05-2012 | 11:57 AM
  #37785
http://www.rcprogear.com
LloydLoar is offline
