RC10B4.1 FT/WC
Anyone have alternative for the BB spring mod on the shock ends?
Losi TLR5095 seems to be out of stock everywhere....
I ordered all of it from RCPl...t and got an email from PP that they refunded part of the order, which was the item above... couldn't cancel the order so now I need to order them somewhere else. I will never order from them again, I would of at least expected a call/email telling me they were out to give me that option. So I am getting everything but the most important part to complete my mod....
Sorry for the rant. Any alternatives. - Amains server is jammed, can't get on the site.
This place is showing them in stock...http://www.thercshack.com/tlr5088rea...de222-1-1.aspx and this place too...http://gshobby.com/content/losi-tlr5...-12mm-shock-22
i used the top and the bottom parts from the traxxas upper and lower combo...
just took alittle rub with a body reamer to make it slide on good, stays on very well... only time i had one come off was when i broke a front bulkhead from a pretty decent crash over a triple into a wall lol
Registered User
i am currently running the brent thiekle sertup which requires the ballast, i have the complete setup on the car except shaving the ubrace, i wnt to make the car faster as i lap times and im running stock and gered at 75/32 i am running gold barcodes on high grip indoor clay and the car runs great i just want to know what can i do to get my car in the fast guys time frames of like 17.2- 17.7 i am comsistently getiing 18 all day but im gettin fustrated cause when i do make a change to make my car a lil quicker it is a bit harder to drive so i drive it where it is comfy to me and im back to the 18's again can i get a lil good word of advice?
Not sure if anyone else is running into this problem but in AZ it is literally impossible to find the Losi spring cups for the 22 BB conversion. So I have found a decent alternative for people who just cant wait. I bought some of the older Losi spring cups like the ones found on the XXXT part #LOSA5079, and then I bought 4 of the TRA3768 shock collars. The spring cups are just slightly smaller than the 22 cups, so I took a razor blade and split the traxxas collar so I could fit it over the spring cup. Then I super glued the traxxas collar to the spring cup and cut the shaft opening the same size. Spring sets on it perfectly. Fits the AE shock end perfectly. Obviously its easier to use the Losi cups, but they are M.I.A. Out here. I will post a pic in a minute.
Have any of the guys that are looking for spring cups tried either of these two sites? http://www.thercshack.com/tlr5088rea...de222-1-1.aspx and this place too...http://gshobby.com/content/losi-tlr5...-12mm-shock-22
