RC10T4.1 Thread.
Old 02-12-2012 | 06:40 AM
  #496
racer1812's Avatar
Super Moderator
Originally Posted by Hinecken
Don't internal limiters provide the same function as downstop screws?
Yes, just take's much longer, along with the obvious mess involved.
racer1812 is offline
Old 02-12-2012 | 07:34 AM
  #497
Cain's Avatar
+1
Cain is offline
Old 02-12-2012 | 12:08 PM
  #498
I'm not wild about downstop screws in 1/10th scale 2wd offroad. I like the overall simplicity of the vehicles as compared to 4wd and 1/8 scale. Also, I once I figure out how many limiters I need to keep the spring seated without adding preload, I never change it again. One less adjustment to double check before a race. 4 less screws in my car to come loose. 4 less holes.
Hinecken is offline
Old 02-12-2012 | 12:17 PM
  #499
Cain's Avatar
I would prefer them as if you need to see how a downstop change would work, you can quickly do that and then later add in the shims to the shocks if you like, versus having to tear the shocks apart to do the same thing.
Cain is offline
Old 02-12-2012 | 12:24 PM
  #500
racer1812's Avatar
Super Moderator
Old 02-12-2012 | 04:28 PM
  #501
Without limiters, or rather with the 2 the kit setup includes on each front shock, the shock shaft extends farther than the spring. With the weight off the wheels, there would be a 1.5mm gap between the bottom of the spring and the retainer. I add limiters to remedy this.
Hinecken is offline
Old 02-12-2012 | 05:25 PM
  #502
racer1812's Avatar
Super Moderator
standard set-up for the front shocks on a T4 is 5 limiters. You're just doing what you're suppose to do..
Old 02-12-2012 | 06:26 PM
  #503
Standard set up is 2. http://www.teamassociated.com/pdf/ca...ndard_2009.pdf
I had to purchase more limiters to increase the amount. RTR does not include additional limiters.
Hinecken is offline
Old 02-12-2012 | 08:40 PM
  #504
Travis107's Avatar
Hey guys, just curious what others are running for non boost/no timing stock class. Any feedback is greatly appreciated.
Travis107 is offline
Old 02-12-2012 | 10:02 PM
  #505
RadioRogue's Avatar
I've got 5 limiters in my front shocks as per manual instructions.
RadioRogue is offline
Old 02-13-2012 | 12:49 AM
  #506
Jake S's Avatar
i run 4 limiters in the outter hole in the front.
http://205.196.123.162/8a926c9p4a8g/...CS_Sanders.pdf
is my full setup, my truck is ALOT better than i am tho hah. its actually pretty close to cav's most recent setup too
Jake S is offline
Old 02-13-2012 | 06:11 AM
  #507
RTR or FT?
Hinecken is offline
Old 02-13-2012 | 10:25 AM
  #508
RadioRogue's Avatar
t4.1 factory team
Old 02-13-2012 | 10:44 AM
  #509
skrichter's Avatar
Default New Setup - Cavalieri
Finally, a recent setup for the T4. Enjoy
http://www.teamassociated.com/pdf/ca...ri_Ohio_RC.pdf
skrichter is offline
Old 02-13-2012 | 09:02 PM
  #510
t4.1 factory team
The FT kit may call for 5 spacers, but the rtr only comes with and calls for 2.
Either way, I'm glad to know I did it correctly without knowing anything about the FT set up.
Hinecken is offline
