RC10B4.1 FT/WC
pretty disappointed with my worlds kit. one of the rear u-brace ballstuds does not have a hex head on it (just round) so I can't even drive it into the brace, and the shocks are not smooth inside
i've emailed AE and will probably get replacements soon, but I was hoping to run a new kit this weekend.
http://imageshack.us/photo/my-images/19/img0245go.jpg/
I would call them direct. I had them ship me some aluminum screws which were missing from a kit. You might be waiting for a reply to your email for quite some time....
I just deal with it. IMO if it's not "chattering" through the corners, it's not dialed. Haha.
Sorry if this has been covered already. I did some searching and couldn't find anything.
Last night I replaced a bad bearing and all of the gears in my gearbox and the gearbox is tight (doesn't spin freely) and it gets tighter the more I tighten the screws. This has happened to me before and I can't figure out the rhyme or reason. Does anyone have any experience solving this issue. Thanks in advance.
yeah I called them already and they said they'll take care of it, just need my receipt from the hobby shop, then I called the hobby shop and he says he'll just replace it, so I'm covered either way.
edit: yes chris is the person who i spoke with and both him and don are great to deal with.
Looking at it more I noticed that having left side of the transmission case off, that the gear on the top shaft did not line up horizontally with the idler/diff gear. All bearings were seated correctly and everything assembled correctly.
After more investigation, I found the culprit was the silver aluminum sleeve used to space the top-shaft. It was two long. So, I carefully sanded it down with sand-paper, may have removed about 1/32 to 1/64 of and inch. Just went little by little until I not longer got binding for reasonable snugging of the transnmission housing bolts
Also, I did not use the washers for the transmission bolts. You don't tighten them that much anyways, and I felt the depth of thread engagement was no good with them.
After these mods, the transmission runs nice and smooth.
The hex fronts get rid of just about all the slop if you go that route at some point down the road. Its really nice not having to pull bearings all the time too... or if you don't want to do hex, let me know. I have a bunch of fronts that are much less convenient for me to use now if you need any.
Way tight transmission screws ?
Suggest adding one 3/16th axle shim in ft of top shaft spacer....( not for spacing , better for bearing to ride on)
Also use the servo kit washers, not the metal .030 washer
transmission screw's...
*Lock Tight
note:
If transmission case is well used & screw's were way tight , it is now mostly warped & needs replacement .
I recently build the B 4.1 kit, and even tightening the screws as loose as you could possibly want them, the transmission was still dragging noticeably, and I did not trust with the amount of screw engagement with the motor plate they would stay secure.
Using the top shaft to seat the bearings after trans case assembly will help seat the bearings to the top shaft. Then loosen and snug up all case screws to see if it has helped.
I have NEVER has to adjust a top shaft spacer to make clearance in an AE case... and i have built A LOT of AE trans cases over the years. The only exception to this was the Hydra Drive conversion topshaft for AE cars back in the day... but they used shims... not a spacer.
I know this is the B4.1 thread, but quick question:
Are these wheels actually wider than the standard 2.2 front wheel?
http://www.amainhobbies.com/product_...eels-Yellow-B4
