RC10B4.1 FT/WC
Old 02-02-2012 | 05:10 PM
  #10831
patiofurniture's Avatar
Originally Posted by B.A. Racer
well im trying to turn turnbuckles gold but its not working the simple green fizzes and bubles but when i take it out after 35 seconds its still the same color..7 8v + in water...anything else that could be wrong?
Make sure you are only dipping in the turnbuckle, and not the aligator clip or wire you're using to attach to the turnbuckle.
patiofurniture is offline
Old 02-02-2012 | 05:16 PM
  #10832
B.A. Racer's Avatar
i am doing that.hmm..does it matter what kind of wire you use? im using 20g
B.A. Racer is offline
Old 02-02-2012 | 05:18 PM
  #10833
YankeeFan123's Avatar
So how do you turn them gold? Put n simple green for 35 seconds, take out and attach to battery and put in water?
YankeeFan123 is offline
Old 02-02-2012 | 05:31 PM
  #10834
The wire shouldn't matter unless you are using 22+ AWG, and provided you have enough voltage. Typically, 60+V is suffiecient, so about 7 or more 9V batteries in series.
Old 02-02-2012 | 05:36 PM
  #10835
Tyler Keel's Avatar
8-9v batteries will be enough. Done it plenty of times, like I said before your not using enough juice B.A.
Tyler Keel is offline
Old 02-02-2012 | 05:42 PM
  #10836
B.A. Racer's Avatar
tried that..im doing something wrong haha but i cant figure it out
Old 02-02-2012 | 05:44 PM
  #10837
Tyler Keel's Avatar
Put the negative lead into the simple green and the positive lead clipped to the titanium part, dip it in for about 20-30 sec. and it should work.
Old 02-02-2012 | 05:58 PM
  #10838
B.A. Racer's Avatar
thx man..worked perfect
Old 02-02-2012 | 06:02 PM
  #10839
Littlejohn Dsgn's Avatar
Can you grab a picture
Littlejohn Dsgn is offline
Old 02-02-2012 | 07:04 PM
  #10840
ViGiLaNtE351's Avatar
http://www.youtube.com/watch?v=wyWtc067nts
ViGiLaNtE351 is offline
Old 02-02-2012 | 07:22 PM
  #10841
t.mathewson's Avatar
someone mentioned earlier that if you play with the voltages you could change from silver to different colors. anyone done that? gold's just not for me.. lol
t.mathewson is offline
Old 02-02-2012 | 07:30 PM
  #10842
It can be done, but requires a fair bit more voltage. Google "Mr. Titanium" and check out his Titanium Anodizing how to section. I'd link it, but I apparantly don't have enough posts on RCTech yet
supergleep is offline
Old 02-02-2012 | 07:35 PM
  #10843
B.A. Racer's Avatar
here is the gold turnbuckle after i finally figured it out
Attached Thumbnails RC10B4.1 FT/WC-gold-turnbuckles.jpg   RC10B4.1 FT/WC-gold-turnbuckles-2.jpg
Old 02-02-2012 | 08:03 PM
  #10844
mxracer458's Avatar
Did you dip them when they were still blue?
mxracer458 is offline
Old 02-02-2012 | 08:08 PM
  #10845
http://mrtitanium.com/anodizing.html
There is the link if anyone wants to check it out. I think I might try bright green! It will only take about 14 9v batteries....
