RC10B4.1 FT/WC
Ran ae springs tonight and was 4 tenths faster on my hot lap run. And this is on a rough track. The only change was the springs. So you don't need em. If i go back it will be because they look cool
You can just dip them in as is and they will change to gold. However, unless the turnbuckles are new most people polish them and then dip them. If you get clever with the voltage and the time you leave it in for you can also get several other colors.
What springs did you go back to? Brown /green? what oil? I know i always run the kit springs and never go far from the std oil weights..
just like to ask what voltage/batteries did u use? also how much time did u leave them in, and if its possible to use a power supply of some sort instead of using batteries. does the voltage need to be a certain level, or can a single 9 volt do the job?
http://mrtitanium.com/anodizing.html
im using losi...i used pink last week and it was way to hard for my liking..i only use yellow or white in the rear now...and silver up front
There is a link to the info in bobbarry sig. Losi had been outta stock so some were forced to go with kyoshos outrageously priced springs. Losi is back in stock at amain and other places now
Yesterday I mounted up a fresh set of V2 Gold Bar Codes....
I reused a set of Pro-Line close cell inserts .
Before gluing, I installed a piece of duct tape , filling the inside middle section of the rim.
Used a piece of tape about a 1 1/2 ft long ...
This helps restore the foams profile & fills the airspace created from wear.
Performs awesome & saves you $ as you can get a extra cycle out of a set of foams...
you guys think the +8mm chassis makes a big difference? Does it make the car a little less aggressive? Also Im new to the electric side lol. I have a used ft b4.1 that I just bought. It has a lrp spx esc and I think a novak 7.5 motor. Think the 7.5 is way to over kill for me? The spx comp esc any good? Another dump question, It has a tekin lipo, I didnt know they make batteries but anyways its a 3400 23c. It this battery good enough? I have a 5000 40c think that would be better?
