RC10B4.1 FT/WC
Old 02-12-2012 | 03:54 PM
  #11296
B.A. Racer's Avatar
Originally Posted by Eric Thompson 2
Yes. The +8 is a big difference. Especially in stability.
+1 you will notice a huge difference in performance
B.A. Racer is offline
Old 02-12-2012 | 04:00 PM
  #11297
+1 Definately better performance. My son ws running +8 and broke the chassis before a big race, had to use the short one on race day, and was lost on setup, until I went to Cavs old b4 short setup. The +8 definately helps the overall handling.
msave is offline
Old 02-12-2012 | 04:04 PM
  #11298
So whats the deal with the ghea pistons, I hear so much talk about. People using 1,2,or 3 with tapered or flat gheas, and using along with big bores? What about the v1 spacers? Hear alot of things are working, just trying to get some opinions, as we will be changing to v2's as soon as they get here. Still running v1,s. Lol.
msave is offline
Old 02-12-2012 | 04:35 PM
  #11299
If anyone is looking for a set of B4.1 V2 shocks I just listed some. They are straight out of my new Worlds kit still sealed in the bags. Here's a link to my ad:
http://www.rctech.net/forum/r-c-item...brand-new.html
nhraman is offline
  #11300
DaveW's Avatar
Finally had some dry weather and got the B4 dirty today.
I took advice from a few of you guys and settled on a setup that seems to work really well (as long as the groove stays fluff free).
Front:
#3 piston BOTH holes drilled with #55 bit (basically a smaller holed #2 piston), 30wt oil.
Brown spring, middle top, outer arm.
Rear:
#2 piston with ONE hole drilled with #54 bit, 30wt oil, one .030 limiter.
Green spring, in tower, in arm.
I found an OLD pair of M2 Proline WIDEBODY fronts... reclaimed them and put them on new rims. Theyre perfect for our track. Same rears for comparative purposes to the previous setup.
I ran the battery back, added the weight i made...
... and the buggy is freekin planted and jumps like a starved cheetah.
I made a bunch of other changes too... but these are the most notable compared to my prevous setup.
I didnt get to make adjustments to the speedo (which it needs badly now) as my transmitter took a crap on me in the middle of the last pack... but i look forward to getting to race this weekend. I think the setup will be golden after the speedo changes.
DaveW is offline
Old 02-12-2012 | 04:46 PM
  #11301
Wild Cherry's Avatar
Tech Legend
Nice kitty .....
Wild Cherry is offline
Old 02-12-2012 | 04:55 PM
  #11302
Led Finger's Avatar
Default bye bye castle
Looking to change from castle to Tekin. Which Tekin brushless censored motor and esc to get???
Led Finger is offline
  #11303
I laughed too
Got my car all done for Motorama. Hoping for a fun trip this coming weekend!
Bob Barry is offline
Old 02-12-2012 | 04:59 PM
  #11304
I think it's called the RS Pro. Personally I run LRP and love them. If you go that route, then get the SXX Comp V2
Old 02-12-2012 | 05:02 PM
  #11305
20 SMOKE's Avatar
rspro is for low turn,rs 7.5-17.5 is all you need
20 SMOKE is offline
Old 02-12-2012 | 05:21 PM
  #11306
JEFFs SC10's Avatar
Originally Posted by 20 SMOKE
i was there with jeff,there is a lot to do before you go the the +8,get the buggy setup drive it for a few months then get the +8
Appreciate all the help you gave. The front end was WAYYY too high, I mounted it up the new tires/wheels, I'm sure it'll feel like an entirely different animal.
I think once I get this dialed in, I might not drive 2wd sct anymore which is fine by me LOL.
Might be getting a new Tekin either tonight or tomorrow. too.
side note: what a p.i.t.a it is to stuff those huge foams in the tires LOL.
JEFFs SC10 is offline
Old 02-12-2012 | 05:36 PM
  #11307
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
glue one side of the bead on the tire without the foam in it, then roll the tire inside-out, put the foam on the wheel, and roll the tire back over the foam.
T-BirdJunkie is offline
Old 02-12-2012 | 07:05 PM
  #11308
derekbsmith's Avatar
Default shock oil, front and rear?
What do you guys, who race use for indoor clay tracks? outdoor medium pack? still new to this car and racing. thx!
derekbsmith is offline
Old 02-12-2012 | 07:08 PM
  #11309
JEFFs SC10's Avatar
Thank you TBJ!! I will do that. Don't wanna mess it up.
Old 02-12-2012 | 07:26 PM
  #11310
20 SMOKE's Avatar
then you should have given them to me to do
20 SMOKE is offline
