RC10B4.1 FT/WC
Maybe a bit off topic right now, but does anyone have a good way of getting the receiver wire up the antenna tube on the chassis? The only holes to get up the tube are from the bottom of the chassis or from the side inside the chassis, where you have to get the wire to go in and up to have the tube right.
I wish it was like most other 10th scale chassis, with a slot in the side of the antenna tube holder so the wire has a place to stick out.
Ideas?
Ideas?
if everyone knew the amount of stuff that BWald is responsible for coming to life in the production world, the earth would implode.
I mean think about it.... every major company has a version of his tire
He's a legend and I hope he gets the win this weekend!
I dont see a spring cup on the shock either. To me it looks like a BB sleeve that threads over the AE threads and allows you to use a certain spring retainer. Although that does not explain the missing spring cup. Might just be a picture showing off the sleeve and the springs/cups were removed to make it more visable.
i believe someone on the thread did this a little while ago. from what i can recall, they just dremeled the post flat, drilled a hole and used a cone washer/screw to secure the wing to the posts.
Been running mine this way for the past year or so.
Just shaved the top nubs flat, drilled and tapped two holes. It seems to help with keeping the wing more secure/straight than with the body clips etc.
The shock is a standard v2 shock. He just used a lathe to take the hex off the body. Dont read too much into this, he obviously isn't running the car...he probably built his shocks and didn't put the springs on yet.
Since I didn't see an "Official RC10B4.1RTR thread" I figured this one covers the 4.1 everything?
Anyway, i was thinking about getting either a couple used 4.1s for my kids and picking up some radios.. OR picking up the 4.1 RTR brushless kits they sell now for $250.
Does anyone have any experience with the RTR kits? I'm looking for something they can have fun with, yet something that isn't going to break if they stare at it too long and also something that I can go grab parts for easily. (are team parts interchangeable? -now world I guess) Had thought of the Losi kits but they are like $150 more and I'm not sure they are worth the extra $300 for the pair I'd need to get.
Thanks Guys
Thanks Guys
I think it's an easy car to work on, even for a complete noob like me, and it will provide hours of tinkering fun.. As for those who suggest you should get the world kit or whatever, yeah, you could, wouldn't be dumb by any means. The kit is $250 or so, but you have to paint the body, buy a servo, buy a motor, buy an ESC, buy a controller and a transmitter, buy a battery and buy a charger. If you're anything like me, you're not going to buy crap, so by the time you're done, you're looking at $550-650 easy (unless you scour used parts online for weeks to piece it all together).
I'm sure there are folks that can put it together for less, but if you're starting from scratch, the RTR is just much easier and you can be on the road (with a paint job!) much sooner. Many of the FT parts are just pretty things that won't necessarily enhance your enjoyment of the car or it's driveability. Then again, they certainly don't detract from it. Now, the V2 shocks are definitely a worthwhile upgrade, but if you've read more than 3 posts here, you know that lots of folks aren't using those anymore either (going with Kyosho shocks, Losi springs, etc. etc. ad nauseam.)
Bottom line is, I've been really happy with mine, and I'm glad I went the RTR route. Much easier pathway to the hobby than piecing it all together. In the end, you may well spend more turning your RTR into a World's Car, but it's more likely (in my opinion) that you'd never do all those upgrades to the roller anyway. You'll probably be more like me and blow most of your cash on tires.
