hpi vorza tekno conversion? >
Old 12-15-2011 | 08:05 PM
  #16
sport10's Avatar
The HHH chassis is also an option and might be easier to make work with the tork motor. It will also reposition the motor more like the ve8 and allow more battery location options.
sport10 is offline
Old 12-15-2011 | 08:12 PM
  #17
Z4Kevo's Avatar
Originally Posted by jhassing
okay guys,
I sent an email to Tekno support to ask them what the options for the motor mount were and this is what they said.
"The only option is to grind the large lugs off of the Tork motor so it will fit into one of our mounts."
What about risk of overheating as a result of the mod?
"No risk of overheating. I don't think there is much heat dissipation from the blocks in the first place. As long as your setup is within reason (not running 6s for 20minutes straight for example), it should be fine."
Grid away! Or buy another motor.
Pop off the lugs one at a time with a pair of pliers and then file it smooth. Only took about 45 minutes to do. Now the Tork motor fits comfortably in the Tekno mount. No issues with overheating whatsoever. Runs great.
Z4Kevo is offline
Old 12-16-2011 | 06:46 PM
  #18
Hey Cergai,
Did you find out any more about getting the Tork motor to fit in the v4 chassis?
-J
Yeah my 2200 kv motor stays warm on 6s I'll be grinding down the heats sinks off the motor some pliers for snapping them off works well too the 1/8 mamba doesn't come with the fins anyways so I doubt there will be any overheating
Cergai is offline
Old 12-18-2011 | 10:20 AM
  #19
Hey guys, is this the diff top plate needed to complete the v4 kit conversion?
Hot Bodies Center Differential Mount Cover [HBS67420]
jhassing is offline
Old 12-18-2011 | 01:26 PM
  #20
Use the above if you want to run mech brakes...otherwise the vorza one will fit no dramas.
TRiN is offline
Old 12-18-2011 | 08:05 PM
  #21
I'm sold on this upgrade!
jhassing is offline
Old 12-20-2011 | 05:12 AM
  #22
I justed finished my conversion i did not need the centre diff top plate my one fitted perfectly but I did buy a new 2650kv mamba and hitec servo buggy is amazing now
Cergai is offline
Old 12-20-2011 | 08:11 AM
  #23
Cain's Avatar
congrats. Feel free to post in the HPI Vorza thread, pretty much one stop shop for all D8 style conversions and vorza questions.
Cain is offline
Old 01-25-2012 | 09:46 PM
  #24
rchoi's Avatar
hello
converting my vorza with v4 kit.
manual is in words...how do you set up the servo? little lost here...servo link is short and i need VERY longer one. did anyone had problem with this?
i need pictures!!! not words !!!
rchoi is offline
Old 01-26-2012 | 06:20 AM
  #25
Cain's Avatar
can you take a picture of what you are seeing and post?
Also, a measurement of your link would be helpful too. I am wondering if maybe the D8 nitro setup has a longer link than the vorza.
Cain is offline
