hpi vorza tekno conversion?
#17
okay guys,
I sent an email to Tekno support to ask them what the options for the motor mount were and this is what they said.
"The only option is to grind the large lugs off of the Tork motor so it will fit into one of our mounts."
What about risk of overheating as a result of the mod?
"No risk of overheating. I don't think there is much heat dissipation from the blocks in the first place. As long as your setup is within reason (not running 6s for 20minutes straight for example), it should be fine."
Grid away! Or buy another motor.
#18
Yeah my 2200 kv motor stays warm on 6s I'll be grinding down the heats sinks off the motor some pliers for snapping them off works well too the 1/8 mamba doesn't come with the fins anyways so I doubt there will be any overheating
#22
I justed finished my conversion i did not need the centre diff top plate my one fitted perfectly but I did buy a new 2650kv mamba and hitec servo buggy is amazing now
#24
hello
converting my vorza with v4 kit.
manual is in words...how do you set up the servo? little lost here...servo link is short and i need VERY longer one. did anyone had problem with this?
i need pictures!!! not words !!!
#25
can you take a picture of what you are seeing and post?
Also, a measurement of your link would be helpful too. I am wondering if maybe the D8 nitro setup has a longer link than the vorza.
