Like Tree2991Likes
1/12 forum
Old 01-18-2012 | 07:36 PM
  #37546
I was referring in my previous post to the side shock. I am running the HB center shock now. It is almost like a different and better car. I think the old one had too many rub points for the angle it was at. The side shock is more of a straight push/pull. But what do I know....
mracer is offline
Old 01-18-2012 | 08:44 PM
  #37547
LonnyJ1950's Avatar
I think this is the servo:
http://www.amainhobbies.com/product_...-Heli-MG-Servo
LonnyJ1950 is offline
Old 01-18-2012 | 09:16 PM
  #37548
Originally Posted by DesertRat
Who cares about the servo, I think that's an original Trinity Duo motor, for some reason the setup sheet said he ran a D3, but those are black. If this is the actual car he ran the sheet was wrong.
Motor wires are unsoldered, I'd say he changed the motor for colour coordination.
Danny-b23 is offline
Old 01-18-2012 | 09:19 PM
  #37549
DesertRat's Avatar
Ah well, if the tech sheet said he ran a D3 it probably was a D3.
DesertRat is offline
  #37550
Jim Frahm's Avatar
Originally Posted by Pulfinator
I highly recommend the micro Hot Bodies for the on point car. The CRC Encore shock is very similar and also good. The HB shock may match the car better though.
I just ordered an Xray and Serpent shock. Guess I'll order the HB as well and test them all.
It looks like they all use the same style of spring??
Thanks for the info guys!
Jim Frahm is offline
Old 01-18-2012 | 09:31 PM
  #37551
CypressMidWest's Avatar
Do yourself a favor and order the Encore shock. It is far and away the best shock I've ever used on a pan car.
CypressMidWest is offline
Old 01-18-2012 | 09:34 PM
  #37552
avs's Avatar
avs
the HB, Assosciated, encore and silva shock use the same size spring.
i don't know about Xray, but the serpent shock is shorter length and larger diameter compared to the others.
avs is offline
Old 01-18-2012 | 10:18 PM
  #37553
Jim Frahm's Avatar
No one that I normally order from had one in stock. I will pick one up when I find one.
Old 01-18-2012 | 10:43 PM
  #37554
303slowdown's Avatar
The encore shock is good but its a pain in the you know what to change the length the silva shock is my favorite cause I change pod droop all the time to fine tune
303slowdown is offline
Old 01-18-2012 | 10:45 PM
  #37555
LonnyJ1950's Avatar
You will definitely need Serpent springs for the Serpent shock. Don't over tighten the cap or you'll crush the o-ring seal and it will leak.
Old 01-18-2012 | 10:47 PM
  #37556
DesertRat's Avatar
I change mine the old-fashioned way. The shaft fully screwed on is about 1mm of pod droop, and I never run less, so I just unscrew the shaft a tad and all is well so far. Its not quite as easy as the Silva shock but it works for me.
Old 01-18-2012 | 10:57 PM
  #37557
Originally Posted by LonnyJ1950
That's the one I thought he might be running. I've been running a Spektrum 6040 which is the standard size high speed. Only thing that is a pain is that it is a hair too wide and does not bolt in on both sides. I use a single screw and double stick tape to attach it to my RC15R5. I kind of like the weight of the standard size up front. I only ask because I'm thinking of picking up one of the new RC12R5.1 and doing the Li-Po conversion, and with that conversion it appears you "have" to have the mini size servo.
Fast04STi is offline
Old 01-19-2012 | 01:00 AM
  #37558
If you use this:
http://www.teamcrc.com/crc/modules.p...prodID=7719154
changing length is pretty much the same as the Silva.
InspGadgt is offline
Old 01-19-2012 | 07:59 AM
  #37559
What metal polish do you guys use for the front kingpins? Im using some I had laying around in the garage, but it is almost out...
And is it recommended to polish the link pivot balls? Ive seen some people do this, but I it also seems that the link balls are often teflon/ptfe coated... To polish or not to polish?
JamesL_71 is offline
Old 01-19-2012 | 08:09 AM
  #37560
shanesva's Avatar
Has anyone converted the Team Associated 12r5...to the 5.1 with the lipo conversion? I have the regular r5...not the r5.1 and wanted to purchase the lipo conversion for it...what other parts "if any" will be needed to convert this old 12r5 to 12r5.1 lipo???????????????
Thanks!!!
shanesva is offline
