DX3r issues... help!
Im having an issue with my radio. I just bound a 3rd car to my radio and I rest parameters for that channel or what I thought was that channel and now all of a sudden as soon as I plug that battery in the wheels take off full throttle and i cant turn right. This now happens to all 3 of my cars. I tried rebinding into a different channel and I get the same results. Anyone ever hear of this?
Sounds like the parameter reset wasn’t completed correctly. Did you fully move the controls as described in the directions? Also after the reset you will likely need to reset servos and recalibrate the speed controls, as you are basically starting from scratch if I remember correctly.
What does the Monitor screen show? Should be an indication of what the radio is trying to do.
Monitors were glitchy. No left hand steering either.
U said now all 3 cars. Why did u have to change it to start with?
Also maybe u have to reverse the motor setting from the radio.
If I cant fix this by the weekend Im probably gonna dump it and get the new DX3r pro or an M11x
Try redoing the parameter reset, following the manual (pages 26-27). I suspect this important step was missed:
Rotate the steering wheel full right then full left; then move the throttle trigger to full throttle and full brake. Note: The values will change to correlate with the actual potentiometers.
After the steering and throttle/brakes have been transitioned throughout their stroke, use the roller to highlight SAVE and press the roller to save the calibration settings.
