SC10 4x4 Thread
Kind of a long shot here but are you running the STRC aluminum belt pulleys? I had a similar problem with my truck and tracked it down to the rear pulley having enough side to side motion that it would hit the inner slipper hub. Worth a look. I am not sure if the plastic pulleys would cause the same noises or not but who knows, you may get lucky.
So the center diff works pretty well with the pro 4? I'm interested in picking one up I'm just concerned it would slip and I'd end up squaring off the ball bearings. Other than that it seems like a great idea.
If you are trying to help the weak bec, not really. It needs to go somewhere between the esc and the servo, so the easiest place to tap into the positive and negative wires is at the receiver. If you have a cheap plastic gear servo or one that is broken, cut the plug off to solder the positive and negative leads onto the capacitor. Make sure to take note of what wire coming out of the capacitor is positive and negative.
Thank you so much for this help
..cant wait to test the truck next week..
Hey guys, I am considering a SC10 4x4 for racing. Looking through some of the posts in this forum I am seeing a LOT of mods! What is the deal with this truck? Are these mods necessary? I am recovering from a couple of seasons struggling with a truck that required several mods to become competitive. I would rather not get into this situation again.
With the exception of the saddle packs, the Mac The Knife slipper basket, the sway bars, the yellow springs, and the chassis brace, and some stick on weight, my truck is out of the box stock. If you want to use a 540 motor, you will need a fan for the motor. To me, that's not that much to add.
The other truck I am looking at is the SC10 FT which seems competitive out of the box.
Everything is a trade off.
Nah, I never bought the aluminum pulleys. I just replaced the plastic ones. It worth looking at the clearance though.
My basic setup:
Front: yellow springs & sway 32wt shocks, 30k diff
Rear: blue springs & sway, 30wt shocks, 5k diff
Proline caliber sc 2.0 super soft tires on protrack wheels
Pin mod with garo's and basket
15/62 gearing on the pro 4 gives me enough low end power to make every jump from a stand still at the base.
I use the same basic setup outdoors as well with PL snipers
after the pin mod I have a little to much push and need to lower the front diff fluid (center diff is on the way, going down to 20k after that)
Once the calbers wear down a bit they provide just the right amout of traction for me to get pleny of forward bite, but sill slide around enough in turns to prevent traction rolls.
I'm using the spectum rx cap, it's 4700 microfarad and 10v. Worked fine up until about a week ago when my mmp stopped letting the motor turn when running at 6.0v. got the bec on the way.
My basic setup:
" I'll probably be at hotshots RC either Friday or Monday night if you want to see it in action. I think garodiscs are the cheapest and easiest way to fix the slipper, then the pin mod if you want true 4x4 handling (which will cost you the price of a good drill bit if you otherwise have the tools)
Good tires are always a must, and besides that I think you could hold your own given you have the skills from the races I've been to around GA.
If you trying to decide on 4wd vs. 2wd, you will have 2-3 times the number of competitors to race with on 2wd, but to me 4wd is more fun. I think that will change as this truck and other 4x4's get to be more popular.
Thanks, I have 5k, 10k, 20k, and 30k bottles, do you know if you can mix 5k & 10k equal out to 7k? I'm not the best driver so I may go with 10k first to help me hold it in the sweepers at the 1/8 scale track.
Yea and being a software developer, I can tell you that your much safer using paypal for any small outfit as they may not be handling your data as well as they should be (not aimed at you Manits, just general practice)
While I have been dialing my truck in since it came out, here are what I consider absolutely necessary to have a truck that can win against a decent field:
Slipper fix (pin it on slick tracks, add garodisks, get a clutch basket, or get the new center diff)
Swaybars
Adding weight to balance the car
Those three things will cost you less than $100
Here's what most people are finding to be very beneficial and you can add as you see fit/budget allows, but will probably be necessary to win at an upper level:
Chassis brace (Coyote carbon tube, exotec center chassis, etc. Just to keep belt tension more consistent)
Adding weight on rough tracks (not just to balance)
Saddle packs
RPM A-arms
Modded steering rack (like the rcshox.com ackbar)
As a final word, some might consider a chassis brace mandatory but from a durability standpoint, not a handling one.
Swaybars
Saddle packs
RPM A-arms
5Likes
