Team Associated TC6 Thread >
Like Tree20Likes
Old 12-18-2011 | 06:10 AM
  #5056
mtbboy's Avatar
Originally Posted by idbdoug
Looking at the T6.1 manual,,how much rear toe-in can we set???
Also,are the rear hubs different from the T6??? I don't see 1 degree hubs for the rear on the parts list
idbdoug
Hey,
3.5* is max Rear toe in for most kits and setups.
There are 1* Rear hubs available as I am currently running them.
Dave.
mtbboy is offline
Old 12-18-2011 | 06:15 AM
  #5057
jekyll08's Avatar
has anyone tried 40weight oil in the rear gear diff and what was the result? i'll be running 3.5 no boost so just wondering if it is thick enough any input will be appreciated.
thanks Brian
jekyll08 is offline
Old 12-18-2011 | 07:03 AM
  #5058
mesa80's Avatar
ive noticed the 6.1 kit seems a lot better organized not one problem yet i love these cars almost done with mine been building since friday after work. Im just a perfectionist love this hobby im going to open up our track if i can finish befor 1
mesa80 is offline
Old 12-18-2011 | 08:29 AM
  #5059
Geberit's Avatar
Originally Posted by olly986
We are not talking about Keven setup sheet, but the TC6 manual had mistakes between the steering link/bellcrank.
OK! Now I get it
Geberit is offline
Old 12-18-2011 | 10:28 AM
  #5060
Default Getting back
Quick question. Bought a 6.1 and was wondering if during build, was there anything set up or build wise that I should do differently or change right off the bat? For example, when building my dex410 there are certain diff oil weights you automatically start with regardless of the kit instructions. There are shock positions that racers automatically go to. Are there shims or setting (toe, camber
,roll center, etc) that are the default go to that racers are using which are the standard? Trying to avoid the inevitable rebuild right off the go. Any tips
, tricks would be appreciated. Thanks in advance. Just getting back into tc.
Seeds is offline
Old 12-18-2011 | 11:45 AM
  #5061
Setup out of the box is pretty good.
dennisV is offline
Old 12-18-2011 | 12:27 PM
  #5062
piper48
Guest
Posts: n/a
Default TC6.1
Just got mine Friday morning and I'll start my build this afternoon. Last AE car I had was the TC4 and I had good success with it so I'm looking forward to the build. One of the factory drivers in our area suggested box setup works great so that's how mines going together.
Old 12-18-2011 | 12:54 PM
  #5063
cwoods34's Avatar
The box setup is pretty easy to drive in any class that's 17.5 or slower. Of course, that doesn't mean it is the fastest. If you are a newer driver it'll work great and helps keep you consistent.
I wound up with 30wt oil in the rear gear diff. Easy to drive, and it seems to keep the rear a bit tame on low/medium bite.
Once you get the hang of the car or want to run faster classes, I'd suggest shortening the camber links (or at least the rear), and depending on grip level experimenting with stiffer springs.
Also, I would suggest buying Reflex pistons and bladders. They make a big difference with the dampening.
cwoods34 is offline
Old 12-18-2011 | 07:47 PM
  #5064
geeunit1014's Avatar
Originally Posted by mtbboy
Hey,
Dave.
idbdoug
The 6.1 rear hubs are different. If you want hub toe, you change the insert that hoes in the hubs. Front caster is set the same way
geeunit1014 is offline
Old 12-18-2011 | 09:05 PM
  #5065
Default Durability
So out of those that have the 6.1, has anyone seen if the new hubs are more durable than the old pieces? I've built mine but have not run it yet, so I'm curious if anyone has "durabilty tested" (read crashed) their car yet and if so how it fared?
tcdrvr2 is offline
Old 12-19-2011 | 12:19 AM
  #5066
hanzo3's Avatar
Will are release a upgrade kit or Ppl with the reg tc6? Or do we need to buy a whole 6.1 kit?
hanzo3 is offline
Old 12-19-2011 | 06:38 AM
  #5067
I have run my car for a few weeks with no spare plastic parts and not broken anything (knock on wood).
Arms, castor and steering blocks seem very strong.
Josh Hohnstein is offline
Old 12-19-2011 | 10:03 AM
  #5068
AE-Reedy
Apparently you aren't knocking wood!
Sean Cochran is offline
Old 12-19-2011 | 02:00 PM
  #5069
olhipster1's Avatar
Default diff gear help
needs some help guys.
are there any tips on building the AE gear diff?
my gear is leaking big time.
diff halves appear to not seal correctly are there any tricks to keep this from happening.
olhipster1 is offline
Old 12-19-2011 | 02:43 PM
  #5070
Rick Hohwart's Avatar
Are you using the rubber seal?
Rick Hohwart is offline
