RC10B4.1 FT/WC
#8568
#8569
the atachment is an old pic of my buggy when i tried to run one, it just takes a body reamer and the supplied screws.
#8571
c4 step 5 in the manual for the b4, part 6928 am I supposed to NOT use end bolts? In other words to the screws (6928)
just slide in the hole with thread lock and a washer, nothing at the other end holding it on?
below parts 6928, 9630
A. --()--------
B. --()-------0-
so in the above drawing, I should have A not B.
thx!
A. --()--------
B. --()-------0-
thx!
#8572
A. --()--------
B. --()-------0-
thx!
A. --()--------
B. --()-------0-
thx!
#8574
Slid the small washer over the screw insert the screw through the tranny case, they thread into the motor plate on the other side of the gear box
just like C4 Step 6 page 8 I think it is.
#8578
Do I need to get all these parts to run hexes on the front of my b4.1? or are there any parts on it already that I don't need to buy?
http://www.amainhobbies.com/product_...t-Axle-Set-B41
http://www.amainhobbies.com/product_...dapter-Set-B41
http://www.amainhobbies.com/product_...ock-Set-SC10RS
Are the plastic hexes good for the front or are the aluminum ones that Proline and Jconcepts worth the extra $4?
Also what foams do you run in the front tires for an indoor clay track?
#8579
they're 2 separate adjustments. The numbers on the blocks are the toe, anti squat is adjusted with the shims that should be in the same bag. Thick shim is 2 deg. and the thin one is 1 deg. 3 deg. toe block and 2 deg. anti squat is the base set-up.
#8580
Wow used my 13.5 stock motor b4.1 in the mod class finished 5th, was running with the best of the best at my track.
The losi springs that wild charry recommended are so great i dont remember the fronts but pink rears a good, may try a tad stiffer the hole car was planted and jumped good.
Were I really noticed the change was in the moble section were my car use to bounce it now floats over
Def upgrade.
I would like to try the short pack has anybody has success?
The losi springs that wild charry recommended are so great i dont remember the fronts but pink rears a good, may try a tad stiffer the hole car was planted and jumped good.Were I really noticed the change was in the moble section were my car use to bounce it now floats over
Def upgrade.I would like to try the short pack has anybody has success?
