RC10B4.1 FT/WC
#8537
^^^ doesn't matter.
Has anyone who is using RPM ball cups had an issue with the length of the steering TB and the amount of thread that goes into the cup? The RPMS are just a little shorter than the AE ones and just don't put enough thread into the cup for my liking. I run Lunsford TB's just for a little extra length but they don't match..
Same issue on the rear links of the T4, but haven't had a problem with those..
#8540
#8541
#8542
you kinda end up with #2.5 piston
or
in between a #3 & #2 piston
You get just a little more pack compared to a #2 piston
good question
#8545
Hi everyone:I just picked up a BL RTR to compliment my 22.I wanted to see
if it suited my driving style better(it does).The rtr esc,450 bl and 3300 motor
have plenty of rip-I have a tekin rs/duo 17.5 boosted in the 22-but it sometimes just quits for about 2-3 seconds and then responds normally.Its not hot-or overgeared.Is this common on a non sensored system?I race so it can be a deal breaker.I love the car and got a +8 chassis for it.Is anyone else having this problem?Is there a fix?I've recalibrated it a few times still happens sporadically. thanks-
#8546
^^^ doesn't matter.
#8547
mekios, my point was it doesn't matter if you use the long shank on the inside or the outside. And yes the reason to use the long shank on one one end is to put extra thread into the cups.
#8548
#8549
Exactly the problem I had when I went all white rpm's... You would think that would make the longer ends in white.... It's just cosmetic... Running blue longs on the inboard side
