Like Tree5Likes
SC10 4x4 Thread
Old 12-11-2011 | 07:21 PM
  #12346
vr6cj's Avatar
Originally Posted by vito
thanks i have a ? whats the slipper basket do.
search man, all the answer are in this thread. thats whats the feature is for.
vr6cj is offline
Old 12-11-2011 | 07:30 PM
  #12347
Chad Smith's Avatar
I am looking at another servo and the savox 1258TG looks great speed and torque wise. But I heard this servo causes glitching because of the power that it needs to operate. I am running a LRP sxx v2 TC Spec speed controler. Anyone with experiance with this servo did you need anything extra to solve the glitching promblem?
Chad Smith is offline
Old 12-11-2011 | 07:35 PM
  #12348
Mac The Knife's Avatar
The slipper basket (clutch basket) allows you to add one more slipper pad for the rear drive. When a vehicle accelerates, weight gets transferred to the rear. AE only used one slipper pad to transfer the torque on the 4x4, and it wasn't enough.
Mac The Knife is offline
Old 12-11-2011 | 07:37 PM
  #12349
vito's Avatar
thanks i will just bash this kit and do i need it ill just lock down the nut
vito is offline
Old 12-11-2011 | 07:39 PM
  #12350
JEFFs SC10's Avatar
Originally Posted by symmetricon
DO IT!!! You wont regret it!
Thanks I am, I have it all ready in the box, just waiting to get the chassis then off it goes to Houston, TX.
JEFFs SC10 is offline
Old 12-11-2011 | 07:40 PM
  #12351
Resqnu's Avatar
I installed a bec on my mmp due to comments a about glitches with some servos. I currently run the ae1015 servo without any issues running the bec.
Resqnu is offline
Old 12-11-2011 | 07:41 PM
  #12352
JEFFs SC10's Avatar
you'll have to run a capacitor off your receiver. Your local LHS should have them, I think I got one from Spectrum. just plugs in the extra channel.
I would go with Hitec, you won't have to worry about that problem.
Old 12-11-2011 | 08:16 PM
  #12353
old&slow's Avatar
Default Glitch free savox
I run the same savox 1258 off a novak havoc pro sc /ballistic 4.5 with no glitch buster and have no issues.
I run a mmm / 2650 combo in my losi 8ight with a jr 9100t and glitched like a tweaker the day after payday. Had to run a big ole cap ( glitch buster) in that to make it work. That lasted about 6 months then started to do the brown outs again. 1st thought was cap died , switched out with spare same brown out , ended up dropping in the castle externalbec( what a pain ) and now no issues till the frickin bec unit came lose and rubbed cv and shorted out and fried my jr9100t servo . So long 130 dollar servo, so buh bye mmm esc.
o&s
old&slow is offline
Old 12-11-2011 | 08:24 PM
  #12354
tc5 man's Avatar
Tech Prophet
Originally Posted by Mizchief
I think that the only "must do" mod is fixing the slipper and a good set of tires that fit the track, everything else is personal preference.
I would get the 3pad set of garodisc's first and try out that setup using the stock slipper (using only 2 pads) then if not happy add the basket or do the pin mod.
Thanks im just getting a 4x4 sc that handles good out of the box and no losi ethier . Im going to try to run it as a second class for indoors and a second class for outdoors so a truck that requires tuning to handle right il pass.
If i ran it as a first class than i would get it.
tc5 man is offline
Old 12-11-2011 | 09:07 PM
  #12355
vito's Avatar
where did you guys buy one from?
vito is offline
Old 12-11-2011 | 11:42 PM
  #12356
Every truck requires some amount of tuning. I don't think this truck requires much at all. I built it, installed the AE high torque pads, and race it. That's it. I don't have anything else on it and I do quite well with it. You can read what poeple are saying to do, but you also have the option to do nothing and just use the truck and replace/upgrade whatever parts are causing you a problem. Which for me, hasn't been anything yet. In my oppinion the truck is dialed right out of the box.
Mark K is offline
Old 12-12-2011 | 01:05 AM
  #12357
CoyoteSlash's Avatar
This is a for sure.
tc5 man:
I'm honestly a little offended that you don't care about the second class you want to run. Cause that's what it comes down to when you want box performance and actually compete. The only way this can make any real sense, is if you are running a Stock 4x4 class. Then disregard anything in this post. Then I can see the concern for not wanting to touch your truck and only the Radio.
"requires tuning to handle right then i'll pass": gets under my skin.
I'm not raging or anything, I just can't understand if you actually are a racer, why you would assess tuning as 'not an option'. 2nd, 3rd, 4th, or 5th Class. What a Cop out.
OFNA's require alot of work
Losi has to get lightened up
AE's has to get weighted down
SL4x4 have to be completely restructured
(to list a few things)
'ya got my eye twitchin' sonny!
CoyoteSlash is offline
Old 12-12-2011 | 04:38 AM
  #12358
Farmer_John's Avatar
Originally Posted by CoyoteSlash
This is a for sure...
...'ya got my eye twitchin' sonny!
Do you ever get the impression you take this a bit too seriously?
Farmer_John is offline
Old 12-12-2011 | 05:39 AM
  #12359
MantisWorx's Avatar
i agree with Coyote in that no truck runs perfect out of the box and the SC10 actually runs damn good out of the box with the proper tune and a bare minimum of garodisc and sway bars. the money you spend for those parts will be the same amount you will have to spend on broken part with every other truck!
I doubt your TC5 runs great out of the box! i know mine didnt (shocks are crap, thats 100.00 right there!)
MantisWorx is offline
Old 12-12-2011 | 05:40 AM
  #12360
This debate about what is needed and not needed is very funny. I get beat by box stock with just F/R swaybars. 95% of it is all about driving better. 5% set up and the big part of it is correct tires.
My current set up saddle with Coyote brace, clutch basket and swaybars is it really needed, no but this hobby is about trying new things. Some might think it's worth it, some not.
Plus one's racer set up doesn't mean it's going to work for you everybody drives different.
Just my 2 cents
jmoneym is offline
