-   Rookie Zone (https://www.rctech.net/forum/rookie-zone-7/)
-   -   ESC Question (https://www.rctech.net/forum/rookie-zone/994580-esc-question.html)
Mr_RCGuy 08-10-2017 12:15 PM
ESC Question
Hi,
I am looking at this ESC. TBLE-02
https://www.tamiyausa.com/items/radi...rushless-45057
It states (Sensored-Type, 10.5T, 12.5T, 14.5T, 16.5T). Since higher T's are lower RPM's, shouldn't it be able to use say a 17.5t or 21.5t motor?
Or... does it have something to do with the firmware of the ESC?
I have seen the lower limits on ESC's but, never a high limit.
Thank you,
Adamska27 08-10-2017 12:22 PM
I don't see any issue using lower wattage motors (more turns)
But I wouldn't really recommend that Tamiya ESC
Find something that says Hobbywing that meets your needs at that price range
MarkA 08-10-2017 12:22 PM
Yes, if any ESC says 10.5 max, it means it will actually run anything numerically over that turn rating just fine.
Mr_RCGuy 08-10-2017 12:24 PM
Thank you for the input!:) I am researching the stock Mini kits and I believe it comes with them. I am going to want a brushless motor and hoping I can use a 17.5 or 21.5. And yes HW is my go to. :)
Take care,
Mr_RCGuy 08-10-2017 12:26 PM
Thank you for the help!
Optima85 08-10-2017 03:41 PM
just be aware that that esc does not have a lipo low voltage cutoff if you plan to run lipo batteries. it is fine for life or nimh batteries.
Optima85 08-10-2017 03:44 PM
the tamiya does not have lipo lvc. the hobbywing does have lipo lvc.
phinsfan76 11-08-2017 05:31 PM
Just means 10.5 is the lowest turn it can handle.
Originally Posted by Mr_RCGuy (Post 14999064)
Hi,
Thank you,
Mr_RCGuy 11-09-2017 04:15 AM
FYI, folks. It did matter in this case. The ESC would not run the 21.5T motor. It cooked the ESC. I tried it on two of the same kind TBLE-02. I believe it can't handle the timing properly and there are no timing adjustments for it. Luckly the second one wasn't damaged. I went with a matching ESC from the same manufacturer of the motor. Works great.
Hope this helps someone. Take care.
