tires help
tires help
I wanna get different tires for my dhk brushless razr.the stock ones are ok. But I want like mud tires if that makes sense
You'll need to confirm that truck uses the standard 2.2" diameter wheel but assuming it does, I believe these are what you're looking for: http://www.amain.com/pro-line-masher...p385833?v=5268
Thanks I think it's a 2.1 tire
2.1" would be a very unusually sized tire for what is supposed to be a quasi-stadium truck. I couldn't find the manual for that truck online so if you have it, maybe it will say in there but if that is the case, your tire choice will drop dramatically. Or if the manual doesn't say, you may need to take to a local hobby shop and see if they could test-fit something for you.
Ok I looked it up and it said (4.3 in/2.1 in)
