Go Back  R/C Tech Forums > General Forums > Rookie Zone
Need Help removing stripped head grub screws on MIP X-Duty Drive hubs. >
Old 12-06-2014, 11:02 PM
Default Need Help removing stripped head grub screws on MIP X-Duty Drive hubs.
Hello all I'm needing a little help. As the title states how Do I go about removing Grub screws with stripped heads from the Drive hubs of the MIP X-Duty axles?
CptKlink is offline
Old 12-07-2014, 02:14 AM
ozziii's Avatar
If there is a way to cut a slot into the grub screw then you can use a flat blade screw driver, I used a cheap dremel type rotary tool with very thin cutting disc but that was only on a counter sunk screw so was easy to get to.
Another option is to try a reverse drill bit, or reverse thread drill bit or whatever it is they are called, another option is an "easy-out", they have a reverse thread that screws into the screw head, may have to drill out the grub screw to get it to work though.
Heat the grub screw before trying to get it out, the heat helps loosen tight & threadlocked screws.
ozziii is offline
Old 12-07-2014, 02:59 AM
blis's Avatar
Im with OZZII
If it's a 1.5mm then a 1.59 imperial would do the trick.
Otherwise all you can try is jam a flat blade in there and hope for the best. Or find a reverse threaded screw of types. Maybe a turnbuckle...
Running out of ideas now... eeek.
blis is offline
Old 12-07-2014, 06:45 AM
Ya I was thinking I would need some sort of screw extractor like maybe left hand drill bits or easy outs. I have tried cutting a groove in to the grub screw to use a flat head screw driver but I can't cut in to it enough for the flat head screwdrive to bite the groove and remove the set screw. Unless I start cutting in to the drive hub and i don't really want to do that.
CptKlink is offline
Old 12-07-2014, 01:36 PM
B16A2's Avatar
As a last resort you can drill off the screw head. With the head gone you will just have to unscrew the shaft of the screw with pliers. The remaining screw should only be finger tight if it is screwed into aluminium however may require effort if it was screwed into plastic.
B16A2 is offline
Old 12-07-2014, 03:17 PM
umm with a grub screw there is no head. And the Grub screw are screwed in to steel with gel loctite.
CptKlink is offline
Old 12-07-2014, 03:20 PM
B16A2's Avatar
yeah your right. I'm tripping. I was thinking screw with head.
B16A2 is offline
Old 12-07-2014, 03:29 PM
Never tried easy outs or left hand bits. My last resort is to jb weld an Allen key into the stripped screw, wait a day and then remove the screw. Good luck
rcdaddio is offline
Old 12-08-2014, 07:36 PM
ingannilo's Avatar
This is good advice. For a grub screw, probably the best bet. Hard to find an extractor kit small enough to get a <2mm grub screw out. Easier and cheaper to sacrifice an old allen key.
ingannilo is offline
Old 12-08-2014, 08:05 PM
Micro easy out. If you have an rc car you should have one.
sobiski racer is offline
Old 12-08-2014, 08:11 PM
thebombster's Avatar
You can try putting a piece of wax paper in the head so the hex has so,etching to bite to break it loose, sometimes it works, you can try slotting it with a dremel but I doub there is anything sticking up to slot, you could drill it out aswell
thebombster is offline
Old 12-08-2014, 09:57 PM
Ya I have just bought a set of screw extractors and also a set of Micro Grabit's going to try both
CptKlink is offline
Old 12-08-2014, 10:29 PM
R1Joel's Avatar
Good info thanks guys. I just stripped the grub screw on my sway bar links.
R1Joel is offline
Old 12-09-2014, 05:45 AM
lbenton's Avatar
Trader Rating: 48 (100%+)
On like a sway bar, if you used loctite on it, I would suggest one battle at time. Acetone bath for a while or cook it in the oven or with a heat gun a while to break down the loctite. Then do whatever magic trick is needed to back the screw out.
lbenton is offline
Old 12-17-2014, 08:01 AM
What's the word cptklink? Any luck? Are you certain they are stripped? Reason I ask, I just found out the Robinson racing pinion I put in my ruckus has a 1/16" hex screw, slightly larger than 1.5mm. Thought I stripped it with my 1.5mm hex wrench but it's all good with a 1/16 wrench.
rcdaddio is offline
