Go Back  R/C Tech Forums > General Forums > Rookie Zone
Binding issue >
Binding issue
Binding issue
Old 10-21-2014 | 09:05 PM
Default Binding issue
I've upgraded my receiver and transmitter to a turnigy gtx3 with the matching receiver, which works well. i also bought a hobbyking hk-gt2e receiver for a different car I am building.
im having trouble binding the turnigy and HK together, i can't seem to get it to work. lots of different combinations from different sites and videos, but no troubleshooting seems to exist on this internet. Is the receiver just no good?
if they aren't compatible i guess im only out $9
thanks
pcweasel is offline
Old 10-21-2014 | 09:38 PM
blis's Avatar
thanks
I dont know the equipment, but if Trasnmitter supports DSM modes and Frame Rates, try tweaking them.
blis is offline
Old 10-21-2014 | 09:58 PM
do you mean if it has more memory modes, because i tried all of them. as well as binding the receiver that came with the transmitter to another number and it worked. it just seems the the HK receiver doesn't work.
pcweasel is offline
Old 10-22-2014 | 12:14 AM
blis's Avatar
DSM, DSM2 and various other communication protocols.
See Spektrum.
For Futana it's FASST
http://www.futaba-rc.com/technology/fasst.html
The transmitter may have configuration options or look up the manual to find out what technology it's based on.
Hobbyking GT2E AFHDS 2A 2.4ghz 2 Channel Radio System
Features:
• Reliable, interference free 2.4GHz AFHDS signal operation
• 2CH operation
• Use only 4xAA batteries for transmitter
• Adjustable steering dual-rate
• Simple binding procedure
Transmitter Specs:
RF Power: 20dBm (100mW) max
Modulation: GFSK
System Type: AFHDS 2A
blis is offline
