What does this justock esc come with?
Hi, I can't tell if this hobbywing justock 45a esc comes with anything besides the esc. I would be using a fantom apex 17.5 brushless motor. Does it come with power switch, fan, wires or sensor cable? On hobbypartz it shows it with a fan and wires. But on this site it just shows the esc.
justock esc-
http://www.falconsekido.com/products...c-blue-edition
hobbypartz-
http://www.hobbypartz.com/07e-justock-blue-esc.html
On a sidenote, would this esc be just as good as the justock?
http://www.hobbyking.com/hobbyking/s..._10th_esc.html
Any help is much appreciated.
justock esc-
hobbypartz-
maybe durability is not the right word. it might be more "temperamental" as it is a lower quality electronic piece. if you are just running 17.5 blink, stick with the just stock. I'm not sure if it comes with a sensor wire, but you will probably want to buy one the right length.
Okay, I've always been one to buy something cheaper, if it works as good as something a lot more expensive. I'm not one to buy top of the line stuff, mainly because I just can't afford it. Do you know what the right length would be? I'm guessing it just has to be long enough to go from esc to motor...
