Cant get Toe equal on both sides
Trying to do toe out and on the left it does it but on the right it won't go as far as the left. Took off turnbuckles and rebuilt them to the same size(did this with camber and toe). The right toe turnbuckle doesn't seem to be able to get any tighter but it's the same length as the left...what else could be making it not be equal?
Here is a picture....
Have you tried adjusting steering trim? Be sure to check endpoints/travel too if your radio has it, get full turning each way without binding/bottoming out.
Reason is the servo horn end of the link is frequently higher than the steering arm end. Turning in either direction flattens out the link, causing an error in the same turning direction (hope that makes sense, tricky to explain). Some servo horn offset helps balance it out, can make the on center steering more equal (although never perfect).
Your steering linkage is too long. Look at the pic from asc6000. That is how it should look.
Yours has a gap between the ball cups. Tighten that linkage up so there is no gap. Then make the turnbuckles the same length and recenter the arm on your servo.
http://www.petitrc.com/setup/kyosho/...RCHR201010.pdf
I'm hoping it works for my track-(we normally run opposite of video)
http://www.youtube.com/watch?v=1KSOS5KuI3Y
