Battery Help
Battery Help
Hey guys,
I just recently got into the RC world & I purchased my new HPI E Firestorm 10TF
which I am waiting for it to arrive. It says it is capable of handling a 3s Lipo.
The issue that I am having is that I cant find a 3S that has a running time of
40min-1hr which is what im looking for. The other ones I found online have a run time of below 30 min, which I dont want. I understand that im going to need to get use to the throttle control but I dont mind. Also, if anyone can recommend the proper charger/balancer for the car that would be great. Any help & suggestions Id greatly appreciate it .
Thanks !
Thanks !
you're probably asking way too much for a battery. but try to find the highest MAH you can is about all you can do.
of course most of us buy several batteries. they're usually done charging by time the other one is done. if you get a high enough amp charger.
here's a 6500mah
http://www.smc-racing.net/index.php?...product_id=169
here's a 6500mah
3s is a lot for that car. I think max amps has some 10,000 + mah batteries! but they are so expensive. Don't even know if they make them anymore.
Standards runtime is between 25-40 minutes for a car like yours, with a standard capacity battery (something 3500-6500 mah.)
Well im in the rookie zone for a reason lool, I just thought they may have a lipo battery that runs for that long. But Im liking the one you recommended. If I were to get that battery and purchase the " Thunder AC6 smart charger" would it be safe to use it on the battery?
Ok Ill check it out thanks for the help again guys. Im just trying to make sure I get the proper equipment without any malfunctions . I will keep you guys posted once my first baby arrives and post up some pics!
I highly doubt the firestorm elecs will run for an hour on 3s without heating up to bad temps
I think my attention would be drawn elsewhere after an hour too. "Squirrel"
But it says on the box that the car can handle a 3s? Doesnt that mean that the gearing and motor/esc are set from the factory for it to handle a battery at that kind of power?
It may come with an optional pinion gear for use with 3s like the 4x4 slash did or it could be setup already somewhere in the middle for use with both. But I believe the point he was making that it probably couldn't handle a solid hour of 3s abuse, working a motor hard for that long will generate a ton of heat, heat kills motors.
nanotech 5300 mah
http://www.hobbyking.com/hobbyking/s...arehouse_.html
or for longer run times the nanotech 6600 mah
both are very good value
Previously Posted by Speedo711
What would be the approximate run time for the 6600mah ?
not necessarily...the maximum cell rating is an advertising point. I would recommend a 2 cell for starting off. I would start with a..
"It can handle 7.4 volt (2S) or 11.1 (3S) LiPo batteries as well as 7.2v NiMH batteries for a range of possibilities " from wwwhpiracing.couk/piw.php?partNo=106628
I was definitely getting way too excited of running a 3s with high mah bone stock.
So is my best bet for this car to run on a 3s with low mah, for a 40 min run (stock) &/or a 2s with high mah long run (stock) without having any heating issues?
