-   Rookie Zone (https://www.rctech.net/forum/rookie-zone-7/)
-   -   Car doesn't work when on the ground (https://www.rctech.net/forum/rookie-zone/784333-car-doesnt-work-when-ground.html)
CookieFlow 01-09-2014 11:45 AM
Well after 1 hour 30, the car is reassembled and it was indeed the problem ! :tire:
Ps : The left wheel doesn't turn at the same speed as the right wheel when dragging it on the rear wheels or moving the spur gear manually.
Is it something I should be concerned about?
:smile: Thanks you so much for the help guys ! :smile:
WonTonsChicken 01-09-2014 12:01 PM
Im curious how you got it together backward... Everything lined up nicely?
CookieFlow 01-09-2014 12:07 PM
Yes everything worked fine when pressing the trigger and the pieces lined up, I guess it's pretty easy to mess up if you don't know.
orangutanracer 01-09-2014 12:14 PM
It should turn the same speed as the other wheels. Maybe you got a bad bearing or something binding that left wheel.
CookieFlow 01-09-2014 01:03 PM
I will look into that !!
Thanks again :smile:
ThePanda 01-09-2014 01:14 PM
traxxas bearing rust out and bind up easy.
CookieFlow 01-09-2014 03:23 PM
noted !! thanks !! :nod:
RCNYWOLFTEAM 01-09-2014 08:34 PM
Try Checking Your Slipper Clutch It Might Be To Lose
