Go Back  R/C Tech Forums > General Forums > Rookie Zone
Servo receiver problems >
Old 08-13-2013 | 08:25 PM
Buggy kid90's Avatar
Angry Servo receiver problems
Just finished my mbx6r kit installed two hitec 7954s and im running them with
A sr3100 receiver everything was good until I set the fail safe and both servos bound up steering went hard left and throttle went in to the fail safe mode I set which was full brake. Hooked the batt up in my ofna buggy and it was fully charged. Went to hobbytown they couldn't figure it out. Tried a capacitor didn't do anything this is my first kit and I'm just frustrated. I know I'm pretty much screwed and have to send the servos and receiver out. Should I go with other servos or is it just the receiver? Advice would be appreciated.
Buggy kid90 is offline
Old 08-14-2013 | 03:57 AM
Try backing off the full brake on the failsafe setting. That could be stalling the servo and drawing the voltage down. Especially if you have a very aggressive brake endpoint setting (which is hard on the servo anyway). What receiver battery are you using?
Dave H is offline
Old 08-14-2013 | 09:33 PM
I'm running a spektrum sr3100 it doesn't even light up when I plug everything in. I have a protek 6 volt 1600 mill flat pack and I can't adjust the EPA now I get no response from my transmitter to receiver I'm pretty sure it's shot. I also tried resetting the transmitter and it still did nothing I tried using the spektrum receiver that came with my transmitter and it has the same problems.
Old 08-15-2013 | 03:20 PM
No light on the receiver? Try unhooking the servos, make sure the receiver pack is connected correctly, black-negative to the outside. Try binding with a different fresh transmitter model.
Mentioned resetting the transmitter? Reset the parameters? If memory serves if you do that you need to go through the full calibration procedure, or weird things happen.
Dave H is offline
Old 08-15-2013 | 04:25 PM
I just order a new receiver and I'm sending the old one to horizon for them to look at.
Should I keep these servos or should I get something else?
