The right way to set car's alignment
3 Attachment(s)
I have been having a problem setting the "alignment" on my RC8.2 FT...the car wants to pull left, and it seems that I have to correct this with an excessive amount of steering trim.
This is what I have done so far / per the manual & various tips that I have read: 1) Set the steering servo horn as close to perpendicular to the body of the servo as possible. 2) Fine tuned the position of the servo horn using the steering subtrim 3) Adjusted the link between the servo horn and the servo saver arm so that the screw thru between the link and the servo saver arm is in line with the mounting posts of the servo saver (see picture). 4) Toe & Camber linkages were prebuilt, but i verified that all linkages were within 0.1 mm or less to the specified lengths in the manual using digital calipers Questions: Should adjust my cars steering by adjusting the lengths of the camber and / or toe linkages or something else (labeled #1 and #2 in picture) Does the car seem to have an excessive amount of camber (see picture)...unfortunately, I don't have a camber / toe gauge. |
Just set the trim to the center and the servo horn to the center as well, then tune with the turnbuckles!
Off-Road? Yeah don't over think it. you should be able to eye-ball it pretty close then fine tune with the radio.
Which turnbuckles would decrease the pull to the left? The camber or the toe or both?
Originally Posted by blckparade
(Post 12425247)
Turn your radio on. Not the car. Set every Steering setting on your radio to neutral. Set the dual rate to 100. Now take off the steering servo horn and turn the car on. The servo will center itself. Put the horn back on and find the spline that gets you closest to center. Your probably going to have to trim it a little bit. Don't forget blue locktite on the servo horn screws.
(Post 12425247)
Adjust the link between the servo and servo saver to adjust trim. Try and keep the servo arm and the saver arm pointing in the same direction, parallel to each other, to the extent possible. Put the car on the wheels to set and measure camber. Use something like a pop can up against each wheel to eyeball camber, get each side equal. Works on the rear too. |
Great advice
I kept reading this issue over and over, knew the answer, but couldn't put together something as easy to follow. :lol: You can wear out turnbuckles and yourself trying to set it up any other way, learned that one the hard way. :nod: $.02
