soldering
soldering
I have a quick question, Ive been watching alot of racers and they all seem to solder everything, why couldnt they solder connecters on everything then when they need to repair just unplug? I guess this is a dumb question but im new to all this. Im wanting to start racing mine, I just dont really know all the ins and outs. thanks
Soldering connections saves weight, plus there is less of a chance of something come disconnected.
soldering is a more secure way of joining your motor ESC etc it also has less resistance tha plugs.plugs become loose after time have a feel of a tamyia style plug after changing battery packs,it is both loose and hot(hot joints mean lose of power and in some cases fire)
the only plugs i have on my electric(OB4) is the battery connections and their the bullet style,same racers even solder their batteries in
hope this helps
hope this helps
I suggest if you are just starting into rcing to use deans plugs. The soldering is great but if you do not have power to solder you are sol.
Also the deans plugs are easy to use and well worth the lack of the hassle of soldering.
I direct solder for indoor carpet since I know I have power and such but for outdoor offroad I use deans plus.
Also helps so you do not solder things in backwards and fry a speedo or something else. Has a friend do it to a gt7 - snap, crackle, pop, no more racing.
Just a thought. I would hold off on the direct solder.
mc
mc
Just out of interest, has anyone damaged the fets in the esc by soldering direct to the motor ?
When I was soldering deans connectors to the esc, you can really feel the heat from the soldering iron travel up into the esc.
Last post is very true, you should not hold the iron on the wire and let it melt the solder, that will damage the internals. The iron should be able to almost instantly melt the solder in the wire
Super Moderator
Originally Posted by bvoltz
Dose anyone have any opinions on this "ColdHeat" product? I'm new so, do get to upset with me... I need to purchase a iron, so I'm just asking if the product is option.
