Need Help URENTLY SERIOUSLY
Hi Everyone,
I need some help with my TB02, currently I'm using LRP F1 Pro Unlimited Turns ESC and Team Orion BB 10 Turns Motor and Sanwa MX3 Transmitter.
The problem is, my Steering is working but my Throttle will not start and even reverse.
What actually is the problem with my car? Iszit the Receiver spoilt liao or the setting of my Transmitter or ESC?
Please help me.
Thank You
Please help me.
Thank You
Make sure the front and rear diffs are installed in the proper direction. If one of them is installed backwards it can cause the drivetrain to work against itself (I've actually done it).
Make sure you set up the speed controller with the 1-touch. Before you do, set all the throttle and brake trims to neutral. Also make sure the throttle is plugged into channel 2 on the receiver and not battery, channel 1, or anything else. Good luck
check that the recever plugs are instald correctly
