How to clean bearings?
Just wondering how to clean bearings?
I believe they're all ball bearings. Some have blue rubber on the side but most look like different layers of metal rings.
I'm guessing for the ones that have rubber on the sides I need to find a way to peel that off, but I wouldn't know how to take apart the layered looking ones??
What do I use to clean and then lubracate after? and what techniques could I use to do so?
Great question BTW.
For any bearings that have rubber shields, use a sharp hobby knife to get under the shield at the inner race. Dont use the knife edge but the dull side to lift it up and out of place. Also be carefull not to stick it in too far and break the tip off For the metal shieds, you are kind of out of luck. A good soaking in solvent or cleaner is about the best you can do. It is very difficult to remove thoses metal shields and even more difficult to put them back together.
Spray your cleaner in the bearing/ cage and roll. spray and roll untill there is nothing left coming out on to a clean rag.
For metal shielded bearings, lay them flat and put a good 5-10 drops of light oil on them and let them sit for 15-20 minutes and the reinstall.
For rubber shielded bearings, do the same but you can use grease instead of oil if you choose. I bought a 3lb tube of lightweight axle grease 3years ago and havent even gone thru a 1/4 of it yet. smear some grease in the balls/ cage and put the rubber seal back in by hand.
Then reinstall in your ride and enjoy.
Great question BTW.
jerms way of doing it is very good but heres my 2 cents on how to do it
- if rubber shielded take the shields off in the same way jerm said too
- put in a little Tupperware container or any container big enough to hold all the bearings
- spray down with either brake cleaner or air intake cleaner (this eats all dirt and oil out of bearings as u will see in the liquid after they soak for a bit)
- then use this on them http://www3.towerhobbies.com/cgi-bin...?&I=LXUST0&P=7
be sure not to over do it on each bearing
- then put sheilds back on and your good to go
make sure you dont destroy or bend the shields horribly when taking them off
It’s not hard to take the shields off of metal shielded bearings, many used to do it routinely long ago when power and battery life was far more limited, and good bearings were typically a lot more expensive. Wasn’t unusual to run only one shield on the outer/exposed side, leaving the inner/protected shield off. Some even ran no shields (mostly oval guys, you know who you are ), depending on the surface.
The shield is typically held on by a snap ring on the outer race. Look closely and you should see the ring and a gap, notice the ends are cut at opposite angles. Use a pointed hobby knife to grab the side that provides a hook to get a hold of. Pull the ring inward and lift a little, and work the ring out. At some point it will probably snap out, frequently it’s more of a challenge to not loose the darn ring than it is to get it out! Put your thumb over (be careful with the knife naturally), do it over a towel, etc, to help keep or find the snap ring.
Once you get the hang of it it’s really pretty easy and quick. Then you can really clean the sucker out. Reoil lightly with your bearing oil of choice (a whole nother discussion lol), reassemble. Make sure you get it in there and seated all around good, or next time will be really easy…hehe.
Since fairly decent bearings are relatively cheap these days, most don’t bother, just replace them. But still a way to save a few bucks, and a rewarding trick for the DIY crowd.
Because of the lower costs I’ve never tried a rubber shield, but I’ll give it a try when I get a chance.
Thank you rcduder, Dave!
I will get that spin lube.
Like he said and yes I was a concrete oval Guy 20 years ago. He must have been too. LOL. Any way yes he's right. U can take the tiny snap ring out with the tip of your hobby knife and tap the bearing till the shield falls out. I never was careful about those shields because they weren't going back on anyway. I still have a bearing blaster and I think they still make them. U put a bearing n and hit it with a few shots of motor spray. Then a few drops of bearing oil and put em back in. We didn't run the shields back then but I did take all the bearings out and clean and oil between rounds. Maybe a little overkill but they were very expensive n the day. Now I'm getting older and maybe a little lazy. If they need cleaning, I'll just put new ones n.
There are a few companies that sell bearings for a buck. IMO not worth my time to tear them apart and clean them.
I'm too lazy to remove shields and just soak and shake them in WD40 to get the grit out.
Then 1 drop of Mobile 1 0wt oil.
The easiest way I found to clean them is by using a skaker bottle. The bottle that has a small metal screen inside (I think it will work with just a small container but you'll need to fish out the bearings). Drop the bearings without removing any covers into the bottle. Spray motor spray into the bottle to fill about 3/4 inch from bottom (too much spray and it won't agitate as well and you'll get tired without much progress). Cap and shake for 30 seconds. Remove cap pull out the screen and dump bearings on towel. Dry and oil them. It really has worked well for me, even with bearings that are gritty. I've tried bearing blasters, ultrasonic cleaners, and even boiling them. The shaker is the quickest and best cleaning method to me thus far!
