Good LiPo charger?
#16
I use Gens Ace 5300mAh 2S packs with my iCharger 208b. I can charge one in about 20 minutes at 20A! (They say on the label that 5C charging is ok, and it seems to be. There's no battery heating at that charge rate, which I find amazing).
With my setup my runtime is longer than my charge time.
#17
Porter what do you use to power the charger?
#18
Possibly 6s if I get into E truggy. Right now I only need 4s at 5amps.
I'd like to be able to charge 2 batts at a time so maybe the Hyperion. I need to do a little research on it but I'm not afraid to spend money if it will hold up.
I can tinker somewhat. I can solder simple stuff and as long as the instructions are detailed I'm comfortable. The power supply doesn't have to be pretty just long lasting and easy to use.
The other option is a converted 12V computer supply, needs about 34 amps. Strongly recommend a server supply, not a PC supply. Perhaps check out feathermerchantrc.com.
2 x 6S x 5A x 4.2V/cell / 80% x 130% = 409.5 watts
Change numbers as desired for other situations.
Holy crap hour charge times.... I was hoping to buy only 2 batteries but looks like I need 4!!! I just bought a E truggy and was going to run it on a 5s around 6000mah but that sounds like a half hour of running for 2 hours of charging.... Please tell me there is a faster way!!!
#19
To charge a 6S at 5 amps requires 126 watts of charger power. So 252W for two. Taking into account charger efficiency (~80%) and recommended supply headroom (30%), need around 410 watts of power supply. Which equates to about a 30 amp bench supply at 13.8V. Check your favorite shop.
#20
Did not want to start a new thread.
I see there are TONS and TONS of chargers out there. I see people recommend $30 ones all the way to $180 + chargers. I finally ordered a SPC LIPO 2s 5000MAH battery. (Never ran Lipos before)I will probably run my RC once or twice on the weekends. And might even bring my RC to work and run it in between jobs. So what would be a good priced/quality Lipo charger/balancer to run given my scenario that people have had good luck with and no problems? Thanks!
#23
Should've created a new thread.
Good choice on battery pack.
Most budget chargers work out just fine.
This at $44 is one of the more popular budget chargers.
If you're looking for something that your local hobby shop is likely to have, look at the similar spec'd hitec at $63.
#24
Also, will I need any special connectors/misc to be able to charge my pack with any of those chargers for my Traxxas? I am looking for a charger/balancer that comes with everything so I can plug it in a standard outlet. Or is that not the case with Lipo charger/balancers?
#25
Most don't, but the ones I linked will both plug into the wall instead of requiring a separate dc power source. Pretty much all chargers will have banana plugs on them to provide power, and then balance ports. The cables that came with your battery should plug straight into either that or a deans plug. Any hobby shop should have plenty of the different kinds of cables to connect whichever type of connector you need, likely a deans charger lead.
#26
Right on. I just don't want to get a battery cooker I have the IMAX B6-AC Charger/Discharger 1-6 Cells (GENUINE) from hobbykings in my cart. Just want to make sure before I bite the bullet. I would be down for spending a bit more for a better product that will be accurate and not cook my new lipo I ordered lol. The reviews seem to be good on the genuine ones.
#29
Any tips on charging it for the first time? How many amps etc.
Thanks.
