brushless system please
Can anyone suggest a good brushless combo that wont break the bank, and tell me the stuff i would need such as fan and gears thanks. ( i have a hsp tribeshead 94115 1/10 if it helps.)
sensored or sensoeless
For a sensored combo i use a Novak gtb2 an ballistic motor but that will put u down 170$.
For something cheaper i've heard the Castle Creations stuff is good,although i'm not sure how hot it runs so u may need a fan and it's sensorless. Other wise u just need a pinion gear and what ever plugs you use for both.
This setup will be faster, cheaper and given Novak's current rep for quality or lack thereforof, probably even more reliable than any other setup you'll find for under $150. Sensorless means the motor can run "rough" at low rpms but is not something I'd worry about if you're not going to be serious about racing in the near future.
Gearing will be truck and setup specific and the only time I've ever heard of yours is in some of your previous posts. Do you know your trucks final drive ratio, i.e. the gearbox ratio, so we can compare it to other more widely known trucks to give you a guesstimate on a gear ratio?
Try a team orion experiance pro 2
Hello
If you want something that wount break the bank try a team orion experiance 2 pro I just put one in my old rusty over the weekend man it screams VERY fast with a 7 cell lipo I used a 6 cell nimh 5000 battery that was new and it was hard to keep it straight money was an issuse with me to thats why I went with the team orion im very happy with it cant weit to race it
Take care and good luck
Jeff
Jeff
