soldering esc directly to motor question...
just bought one of the EZRUN setups and i plan on soldering the ESC wires directly to the motor tabs. the ESC wires are labeled "A,B,C" but no labels on the motor. how do i know which wires go where?
glanced at the instructions and didn't notice anything. but yeah its an 8.5T brushless motor. thanks for the answers. any tips for soldering the wires into the little holes on the motor?
use the hottest iron you can find, make sure that you pre-tin the wires and the holes. meaning apply some solder to both surfaces before you attach them. plus, only leave the heat on as long as you need to to get a good flow of solder. the fumes are also not good to inhale so open a window.
