Soldering questions/brushless ESC questions
Hey guys/gals,
So I have some questions about soldering ESC to motors, and how to connect the ESC to the battery.
So lets say I purchase a brushless ESC, and need to connect it to the battery, but I have to make my own "plugs", how would I do this?
and if I have my ESC connected to a 17.5, and I want to run a 13.5, how would I change them?
Cheers.
Cheers.
Electronic Connections
Since a brushless motor uses 3 wires instead of the 2 on a brushed motor, you would want to geat three pairs of bananna connectors. One for each wire. In order to make your motors easily changed out, you would solder three wires (probably short, 2 inches) onto the motor tabs. Once you do this you should connect the male or female portion of the 3 pairs you purchased onto these wires. It doesn't matter if you pick the female or the male ends to go onto your motors, just be consistent. The speed control wires that go to the motor will then need the opposite plugs connected to its wires. Males plug into females. This will give you an easy way to change out the motors.
Battery Connection
For the battery connection there is only two wires, positive and negative. Most people will use deans connectors. Put the female onto the battery and put the male connector onto the speed control. Make sure you setup the positive to positive and negative to negative or you will have a big fire Read your speed control manual, it should have an explanation.
http://www.youtube.com/watch?v=xZU9rtACdZY
Buy the connectors at your LHS, solder them up, and you're set.
ITS SO EASY!
Thanks for the help guys
