Go Back  R/C Tech Forums > General Forums > Rookie Zone
carburator is stuck >
carburator is stuck
carburator is stuck
Old 03-26-2011 | 11:50 AM
Default carburator is stuck
Hi guys, I recently tried to take the carburetor out of my axial .32rr1 but it wont come out. I did take out the screw that holds it in. it did come out at one time because i had to flip it around to go on my revo. Any ideas on how to get it out. Thanks
revo3 is offline
Old 03-26-2011 | 12:21 PM
Unless you sealed the carb when you flipped it around, there shouldn't be anything holding it except maybe dried fuel/oil mix. Try wetting the joint where the carb goes into the crankcase with some fuel, let it soak a few min and try rotating to get it moving rather than pulling straight up.
Duster_360 is offline
Old 03-26-2011 | 01:44 PM
I already tried that.
revo3 is offline
Old 03-26-2011 | 06:46 PM
No luck then, guess you have a stuck carb. Next step would be to use pliers wrapped in a rag.
Old 03-26-2011 | 08:05 PM
mr.edzadventure's Avatar
Have you tried to take it apart. I wonder if the idle setting screw is to tight.
mr.edzadventure is offline
Old 03-26-2011 | 11:20 PM
Dadic 78's Avatar
Stick the engine/carb in the freezer for a couple hours, then pop the carb out. That's the only way I can get the carb out of my Axial .32
Dadic 78 is offline
