-   Rookie Zone (https://www.rctech.net/forum/rookie-zone-7/)
-   -   How does ESC work? (https://www.rctech.net/forum/rookie-zone/39737-how-does-esc-work.html)
kabam 05-02-2004 08:15 PM
How does ESC work?
Can any body tell me the concept of ESC?? I have the following questions:
- whats the relationship between the ESC compatibility and the motor's number of turns?
- What make an ESC good? Bad?
- How come some ESC can reverse and some can't?
- I've noticed a little button on my ESC (Don't know the name), and whenever something's not right, my friend just clicked on it for many times until he gets it working. He never told me when I asked him about it. What is that button and whats its purpose?
Thank you. Any comment will be greatly appreciated.
DOMOisCOOL 05-02-2004 09:01 PM
Re: How does ESC work?
-Some ESCs do not have reverse because they are used for racing. In racing, you are not allowed to have reverse. If you do have a ESC with reverse, you must turn reverse function off when racing. We have corner or turn marshalls because of this rule.
-The little button is the setup button. Most ESC can be set up with only one button. Some high end ESCs have different profiles. Some for more torque and some for more speed in the top end.
kabam 05-03-2004 09:06 AM
Thanks.
But what's the concept of the ESC?
And, how does the button work? How would I know when it adds more torpue or speed? When I click on the button on my ESC, it just flashed and beeped.
pro3racer 05-03-2004 10:35 AM
okay, the button is the setup button, like said before, if you didn't know that, you should read the instruction manual, because every companie does there button sequence different, the manual is a handy tool.
The concept of the ESC, is take power from the battery, and in very, very quick pulses, gives it to the motor. The better ESC, the smoother and quicker the pulses, also a better ESC will use less power to do the same job, which means better run times becasue of less ohms. The difference is minimal, but it's there. A better esc will also give you a much smoother throttle, because of the smooth more even pulses. It also gives you the chance to change the amount of power being given to the motor(with help of the RX), which means change of speed. Sure you can be a drag car, and just have a switch(which is full powe/no power), or you can get a ESC and have all those in between powers.
That should help you along.
Smoke21 05-03-2004 09:55 PM
The ESC sends power to the motor, when you pull the throttle slightly it gives slight power, the harder you press the more juice
the esc can only handle so much power, so the more demanding Motors, say 13Turn or less needs a better esc that can handle all that power.
Wency_TA03R-PRO 05-04-2004 10:10 AM
Re: Re: How does ESC work?
Kabam - other ESC don't have reverse but instead a BRAKE and Drag brake profile.. :nod: :cool: :)
Pro3racer/smoke21
Kabam - they are right.. Are you familiar with the osciloscope?.. with that equipment these are call as SIGNAL.. :nod: :cool: :) Hope we all help you figure out what an ESC is all about as wel as its function in the kit. :cool: :) :D Bottomline is its the Brain of your kit and the motor is the heart. :sweat: :sweat: :smile: :nod: :cool: :) :tire: :tire:
kabam 05-04-2004 01:33 PM
Ok.. thank y'all for the help.
Wency_TA03R-PRO 05-11-2004 04:39 AM
HAPPY RACING BRO!!! :nod: :cool: :) :tire:
mick 660 05-14-2004 06:28 AM
so if i have a esc rated at 12-36 turns if i go to a 10 turn motor will it kill the esc staight away or will it run for a while
rice 05-15-2004 06:39 AM
don't try it at all. just use the specific esc for the motor to prevent damage. :)
pro3racer 05-15-2004 02:08 PM
it will run for a while, like 2 minutes most likely, and not going full speed those 2 minutes. What kind of esc is it?
mick 660 05-15-2004 04:38 PM
its a lrp ipc super sport 12-36 turns
pro3racer 05-15-2004 07:50 PM
don't go over with the lrp's, never had any good endings from that. Actually, did you want to go with a 10 turn. don't over gear, and if possible solder on a capacitor, a S-diode, everything, and it might save you, but i wouldn't try it. Actually, "I" would, but i don't want to tell some one to try it.:lol:
mick 660 05-15-2004 08:10 PM
i was looking at a 9 or 8 turn motor
i have just got a esc with no motor limit
do you have an recommendations on good motors
thanks:D
pro3racer 05-16-2004 08:43 AM
for mod motors, the Team Orion V2 motors are pretty quick, but i would look into some tuner motors, like Paradigm, best mod motor i have ever gotten came from them. Right now i would stay away from reedy, i've heard of a few bad reply's from there mod motors in TC's.
Wency_TA03R-PRO 05-17-2004 05:13 AM
I also heard of few bad things on the reedy mod motors.. Just want to ask have you tried using the LRP fusion phase 5?. :confused: :cool: :) Did you know any bad news about this mod motor?. :confused: :cool: :)
pro3racer 05-17-2004 12:50 PM
nope, haven't tryed it, actually, i've never seen one, i know about them, but i've never bought one, nor know anyone who has, sorry.
Wency_TA03R-PRO 05-17-2004 03:00 PM
Ok .. tnx anyway .. :eek: :( :tire:
