wires - plugs
wires - plugs
anyone got good tips on solding wires to bullet type (corally type: both male and female) plugs?
Location: Pacifica, California OR Clearlake Oaks, California
do yourself a favor and ditch the bullets, they are the worst connection available direct solder it Btw What are these for? your Motor?
Actually the corally connectors are very good. From what I've heard there on par with the dean plugs. Just scuff the inside of the male plugs then clean them out with motors spray. Saturate the + and - wires with solder then slide them into the male plugs. They should just cool and get stuck in the plugs, then use shrink wrap to make it look clean. The female plugs are usually just soldered directly to the + and - cell on the batt. The only problem with these conectors is that you can fry your esc if you accidently plug them in reverse.
