SC10 Noises
SC10 Noises
I have an RTR SC10. My truck makes a sort of grinding/crunching noise at very low speeds (2-3mph est). The symptoms aren't like that of the diff needing shims. I tore it all the way down and the diff looks fine, gears look perfect. Any ideas on what it could be?
Thanks!
Thanks!
routine maintenance = cleaing the gears and bearings and rebuilding the diff
if you've done none of this maybe it's time
depending on where you ran it, a car/truck can get really dirty in a matter of minutes. "hours" is a long time in the rc world, it is like "years" in a real car.
as I suggested earlier, if you haven't gone through the entire truck and cleaned (not just dusted off) and relubed each bearing and replaced each gear and rebuilt the diff (and cleaned the motor with motor spray, and checked the pinion and spur gears) it is impossible to say for sure. having to do it is called routine maintenance
